hadyn Posted August 28, 2008 Share Posted August 28, 2008 Hi all, I've recently bought some second hand grooved discs, which are due to be fitted this weekend. Here they are: Can anyone tell me which way round the grooves should go, as the original stickers which tell you which way to mount them have long since gone Link to comment Share on other sites More sharing options...
hadyn Posted August 28, 2008 Author Share Posted August 28, 2008 bumpage... Link to comment Share on other sites More sharing options...
j80leo Posted August 28, 2008 Share Posted August 28, 2008 Hi Hadyn i can't remember which way around they went i can't see you pictures at work but i am sure someone on here can help;) Link to comment Share on other sites More sharing options...
Jazzy Posted August 28, 2008 Share Posted August 28, 2008 From a recent thread http://www.mkivsupra.net/vbb/showpost.php?p=2071882&postcount=35 Hope that helps Link to comment Share on other sites More sharing options...
hadyn Posted August 28, 2008 Author Share Posted August 28, 2008 From a recent thread http://www.mkivsupra.net/vbb/showpost.php?p=2071882&postcount=35 Hope that helps Thanks mate thats brilliant. Problem solved Leo - I'll update you about the discs once I get them on, cheers bud Link to comment Share on other sites More sharing options...
j80leo Posted August 28, 2008 Share Posted August 28, 2008 Thanks mate thats brilliant. Problem solved Leo - I'll update you about the discs once I get them on, cheers bud Great stuff fella are you doing this yourself;) Link to comment Share on other sites More sharing options...
hadyn Posted August 28, 2008 Author Share Posted August 28, 2008 Getting a local garage to do the job. I dont fancy swapping the discs and changing the brake fluid myself Link to comment Share on other sites More sharing options...
hadyn Posted September 7, 2008 Author Share Posted September 7, 2008 Do these look the right way round to you guys? Link to comment Share on other sites More sharing options...
hadyn Posted September 7, 2008 Author Share Posted September 7, 2008 The grooves are angling to the rear in that pic arent they? Link to comment Share on other sites More sharing options...
monkey3 Posted September 8, 2008 Share Posted September 8, 2008 As was said in that other thread, the direction of the "pad scrubbers" (grooves) you can see in the picture above is less relevant. The important part is which direction the vents in the middle of the disc go. They should lean back with relation to the main direction of travel (forwards obviously). i.e. they should throw dust and heat out rather than force air in. Link to comment Share on other sites More sharing options...
hadyn Posted September 8, 2008 Author Share Posted September 8, 2008 So they're the right way round in the pic above? Link to comment Share on other sites More sharing options...
monkey3 Posted September 8, 2008 Share Posted September 8, 2008 (edited) You can't tell from looking at that picture. There are grooves on the outside of the disc (that you can see in the pictures above) and there are cooling \ ventilation vanes inside the disc (that you cannot see in the picture). It's the ones that you can't see that matter. If you can, take a picture looking down on the disc or up at the disc so you can see it end on. Otherwise, stick a small screwdriver in to the middle of the disc from the top and see which way it naturally slants (should be backwards) See attached images... In the (high quality photoshop computer generated reality) picture... the (red) direction of travel and the (red) direction of the vanes between the 2 faces of the disc matters. The swept back, like yours are (in blue) and swept forward (in pink) I've seen in both directions. Edited September 8, 2008 by monkey3 (see edit history) Link to comment Share on other sites More sharing options...
hadyn Posted September 8, 2008 Author Share Posted September 8, 2008 So what happens if the grooves are the wrong way around? Link to comment Share on other sites More sharing options...
monkey3 Posted September 8, 2008 Share Posted September 8, 2008 If the vents are the wrong way round: at best, you'll get brake fade at worst and if you leave it long enough you may cook the pads and the disks and need to replace both and maybe boil the fluid as well if you brake heavily all the time. Basically, it's a good idea to get them round the right way. Link to comment Share on other sites More sharing options...
hadyn Posted September 9, 2008 Author Share Posted September 9, 2008 Just noticed that the discs are hot to touch after a short non spirited drive in traffic after less than 2 miles. Is this normal? Link to comment Share on other sites More sharing options...
monkey3 Posted September 9, 2008 Share Posted September 9, 2008 yes, they would be. Are you going to SupraPod? Link to comment Share on other sites More sharing options...
hadyn Posted September 9, 2008 Author Share Posted September 9, 2008 Yeah I'll be there. Im thinking the fact that my flexible brake hoses need replacing might be causing the soft feel of the brakes in day to day driving. However this might be down to just how bad j-spec brakes are Link to comment Share on other sites More sharing options...
monkey3 Posted September 9, 2008 Share Posted September 9, 2008 Yes, I certainly wouldn't touch the discs if I'd done much more than move it around the drive to be honest. Do you know what discs they are (make \ model)? Are you going to SupraPod? Link to comment Share on other sites More sharing options...
hadyn Posted September 9, 2008 Author Share Posted September 9, 2008 Black diamond discs mate. I am going to Supra pod!! Link to comment Share on other sites More sharing options...
monkey3 Posted September 9, 2008 Share Posted September 9, 2008 ok, well if we don't get it sorted before then I'll take a look. Link to comment Share on other sites More sharing options...
