Active spoiler switch
4000gt
hello, what does the active spoiler switch look like and where does it mount? Is it possible to run the active spoiler off this switch manually just up and down without the ECU. i know there are wiring diagrams around there to make it run manually, just keen to use the stock switch it if is possible... cheers!
yes it is possible, I did it, using the trl wiring diagram, all you need is a multimeter to check what the pins on the back of the switch do, you will use 3 of them.
Ok cool thanks. Where does that switch actually mount?
Its mounted in one of the blanking panels beside the traction control switch (infront of the gear stick)
