4000gt Posted August 16, 2008 Share Posted August 16, 2008 hello, what does the active spoiler switch look like and where does it mount? Is it possible to run the active spoiler off this switch manually just up and down without the ECU. i know there are wiring diagrams around there to make it run manually, just keen to use the stock switch it if is possible... cheers! Link to comment Share on other sites More sharing options...
Guest Garfy Posted August 16, 2008 Share Posted August 16, 2008 yes it is possible, I did it, using the trl wiring diagram, all you need is a multimeter to check what the pins on the back of the switch do, you will use 3 of them. Link to comment Share on other sites More sharing options...
4000gt Posted August 16, 2008 Author Share Posted August 16, 2008 Ok cool thanks. Where does that switch actually mount? Link to comment Share on other sites More sharing options...
Guest Garfy Posted August 17, 2008 Share Posted August 17, 2008 Ok cool thanks. Where does that switch actually mount? Its mounted in one of the blanking panels beside the traction control switch (infront of the gear stick) Link to comment Share on other sites More sharing options...
Kev.O Posted August 17, 2008 Share Posted August 17, 2008 Have a look at this: Link to comment Share on other sites More sharing options...
4000gt Posted August 23, 2008 Author Share Posted August 23, 2008 Awesome thanks guys. Link to comment Share on other sites More sharing options...
