Best place to buy zorst gaskets?
hadyn
1st cat to 2nd cat is 2 bolts the only joint that is different is manifold to 1st cat as that has 3 bolts and best to use paste on that join iirc.
I must admit I hate exhaust paste and will always recommend using gaskets, just email Chris Wilson or Gaz @ Envy with what sizes you need and how many. :)
do you need a thicker gasket on the 2nd decat to 1st cat?
Not sure to be honest mate, if you are going double decat and not running silly boost then you should be fine with a normal gasket.
I know Chris sells both, when I bought mine off him I opted for the thicker ones just to be safe, iirc they were only about £7ish each. :D
  • 2 months later...
sorry to bring back an old thread but i need gaskets for a 3" 2nd decat pipe, its goes to a nurspecR at the back and at the moment will bolt to the 1st cat allthough that'll change in a month or so but just need some gaskets in the mean time if anyone has any they're willing to sell or know of a place i can get them reasonably quickly.
