Zofix Posted July 6, 2008 Share Posted July 6, 2008 I remounted the power steering lines, do the system need to be bleeded? I filled some Dexron III oil on it because it lost some when I had the power steering lines off. And now when I started the engine it sounds like someing is rubbing.. Hope you can help me out:( Link to comment Share on other sites More sharing options...
heckler Posted July 6, 2008 Share Posted July 6, 2008 yes, needs to bleeded... Link to comment Share on other sites More sharing options...
Zofix Posted July 6, 2008 Author Share Posted July 6, 2008 I just tryed to turn the car on again, if i turn the steering wheel just a tiny bit, the sound gets alot louder, it must come from the power steering pump, anybody know what I should do? Link to comment Share on other sites More sharing options...
Zofix Posted July 6, 2008 Author Share Posted July 6, 2008 yes, needs to bleeded... Are you sure, a guy just told I didnt have to do it. Link to comment Share on other sites More sharing options...
heckler Posted July 6, 2008 Share Posted July 6, 2008 if the lines are removed, air will be in lines when reconnected, so need to be bled http://www.mkivsupra.net/vbb/showpost.php?p=257746&postcount=7 Link to comment Share on other sites More sharing options...
Zofix Posted July 6, 2008 Author Share Posted July 6, 2008 OK thanks!, it wont harm anything will it? It dosent sound good:( and the sound get ekstremly loud when you just turn the steering wheel alittle bit? Link to comment Share on other sites More sharing options...
heckler Posted July 6, 2008 Share Posted July 6, 2008 dont think it will, but is best to bleed the system Link to comment Share on other sites More sharing options...
Zofix Posted July 6, 2008 Author Share Posted July 6, 2008 Is it normal that it make that sound? Link to comment Share on other sites More sharing options...
heckler Posted July 6, 2008 Share Posted July 6, 2008 Is it normal that it make that sound? nope - not normal - if you bleed it, it wont make that noise Link to comment Share on other sites More sharing options...
Zofix Posted July 6, 2008 Author Share Posted July 6, 2008 OK so I turn the car on, take the cap of the bottle, move the steering wheel slowly from side to side, and refill the bottle. and repeat it? Is this correct? Link to comment Share on other sites More sharing options...
heckler Posted July 6, 2008 Share Posted July 6, 2008 OK so I turn the car on, take the cap of the bottle, move the steering wheel slowly from side to side, and refill the bottle. and repeat it? Is this correct? needs to be jacked up aswell Link to comment Share on other sites More sharing options...
