Which bulbs to paint?
MaRkYbOy72
I have just bought some blue bulb paint with the intention of changing some of the dash lights- which ones would you guys paint to make that interior a little more up-to-date? PS I am not worried about getting different glo-dials etc hehe!
CHeers :)
explain more mate... the dash bulbs that are green simply have a rubber cap over the top which can be removed to then make the bulbs the normal "yellowy" type colour you'd expect.
Speedo etc has 4 bulbs in - 3 large and 1 small. See hecklers website for blue LED bulb dash conversion for locations behind the dials.
The heater control unit will be a pain to paint I'd imagine - I'd just swap them all for LED's instead :)
i know what you mean!! the paint dsnt work!! sorry!!
you will paint it and when fitted back after they dry you will still have yellow light showing with a small amount of blue!! best way is to do a led convertion!! or buy proper blue bolbs!!
and the blue paint you have will flak out after it gets hot...
Speak to Heckler for the dash conversion - very knowledgeable, VERY helpful (Thanks Si!!!) and also sells the bits pre-modded for you, if you're not comfortable doing the work yourself.
Here is hecklers site: http://www.internetwork.org.uk/
A rough idea of stuff you'll need:
Cluster:
3 x 194 refractor LEDs
1 x 37 invert LED
AC Unit:
Soldering iron
3mm LEDs (usually come in packs of 100 on eBay: 3-5000 ohms)
resistors (they will most likely come with the 3mm LEDs to work for 12v)
Odometer:
"gel film"
clear plastic
glue gun
Indicator lights on dash:
2 x 37 invert LEDs
plastic that matches color of your LEDs
Ignition barrel
1 x 37 invert LED
Cigarette lighter
1 x 37 invert LED
Depends how far you want to go with the conversion really. Most of the above is taken from supraforums.com found here:
http://www.supraforums.com/forum/showthread.php?t=388487
Lots of pics for you - you can get the LEDs from ebay(usually hong kong)
The heater unit though is tricky. Heckler is doing mine for me :)
