spinning
gaz1
I had the same recently (Hotpoint). Amongst the hints I was given over the phone were...
(quoted from an on line source to remind myself)
An out of balanced load (too heavy, or a load left wet overnight then spun in the morning after its settled) causing inbuilt out of balance sensor to kick in.
Blocked pressure systems.
Pressure switch faults.
Module faults,
Connection faults and PCB faults, as well as motor faults other than (or as well as) worn carbon brushes.
In the end, a new circuit board fixed it, at considerable expense.
i need a new one i think but cannot find an identical one, i think i need the exact one as its intergrated:( i fear they are no more it was fitted with my kitchen and i have never heard of this one its a diplomat 8512:blink::search:
