bmx1lew Posted April 2, 2008 Share Posted April 2, 2008 I went to change my spark plugs last night, when unplugging the coil packs the first coil pack plug closet to the cam gears crumbled in my fingers! the plastic is so fragile that it crumbled so i don’t have a plug any more except two little wires and the prongs that are usually held in the plug, so any way i left it at that i didn’t want to continue incase it happened to the others, i plugged the prongs into the coil pack however they are not conducting fully as the car is only running on 5 doh! So i guess i need a new wiring loom? Or can i just buy a new plug end, or is there an alternative? Any help would massively be appreciated Lew. Link to comment Share on other sites More sharing options...
Rajinder Posted April 2, 2008 Share Posted April 2, 2008 New plugs from Mr. T. They are cheap. Link to comment Share on other sites More sharing options...
suprab Posted April 2, 2008 Share Posted April 2, 2008 same thing happend to me too..you can buy the plastic plugs and there is a very good "how to" guide on here somewhere..takes you through it step by step Link to comment Share on other sites More sharing options...
bmx1lew Posted April 2, 2008 Author Share Posted April 2, 2008 class! I just orderd one form envy was a £6 I think i would replace them all but on a budget as I've spent so much, but i will order the rest on pay day and replace the lot Cheers Lew. Link to comment Share on other sites More sharing options...
evanshaw Posted April 2, 2008 Share Posted April 2, 2008 same thing happend to me too..you can buy the plastic plugs and there is a very good "how to" guide on here somewhere..takes you through it step by step Can anyone post the link for the how to guide for me? Did a quick search but didn't see anything obvious. Link to comment Share on other sites More sharing options...
bmx1lew Posted April 2, 2008 Author Share Posted April 2, 2008 try here. http://mkiv.com/techarticles/spark_plugs/ Link to comment Share on other sites More sharing options...
Gaz Walker Posted April 2, 2008 Share Posted April 2, 2008 Can anyone post the link for the how to guide for me? Did a quick search but didn't see anything obvious. http://www.mkivsupra.net/vbb/showthread.php?t=61141 Link to comment Share on other sites More sharing options...
evanshaw Posted April 3, 2008 Share Posted April 3, 2008 Thanks Guys Link to comment Share on other sites More sharing options...
