b.weeks Posted March 18, 2008 Share Posted March 18, 2008 Hi All, I'm looking into what sensors can be plugged in to the AEM EMS (which will be running a PHR Stage 2+). Seems to be lots of kits available and I _think_ it means the AEM can measure: EGT AFR (UEGO Sensor) Coolant Temperature Fuel & Oil Pressure Inlet Air Temp Fluid Pressure Brake Pressure (nitrous oxide/brake kit) ... amongst a few others ... For the available sensor kits, see: http://www.prostreetonline.com/s/electronics_aem-engine-management.asp http://www.envyperformance.com/index.cfm?fuseaction=category.display&category_id=26 The two things it seems to miss are the oil and water temperatures. The reason I would like to confirm, is that I'm thinking of getting a Racepak IQ3, which you can interface with the ECU using the AEM V-Net Module (Part Number: 230-VM-EFIAFM). apparently, with the V-Net module it can read from the ECU: EFI Engine Rpm EFI Engine Load EFI TPS % EFI Intake Temp Degrees F EFI H2O Temp Degrees F Custom 11 (ADCR 11) AEM ADCR Volts Custom 13 (ADCR 13) AEM ADCR Volts Custom 14 (ADCR 14) AEM ADCR Volts EGT Cyl #1 Degrees F EGT Cyl #2 Degrees F EGT Cyl #3 Degrees F EGT Cyl #4 Degrees F EFI Voltage EFI A/F 1 Air Fuel Ratio Lambda EFI A/F 2 Air Fuel Ratio Lambda EFI Speed Vehicle Speed MPH Gear Indicator See: http://www.racepak.com/forums/posting.php?mode=reply&f=2&sid=e99e5858f3ac01aa72eb6a15555f36f0&t=8#review The reason I would like it to use the AEM sensors is that: # It makes sense to me to make the readings available to both the ECU and the IQ3. # It means there is no duplication of sensors. # The IQ3 just needs one cable from the ECU linked to it (again, reduces wires). My questions are: # Does anybody by chance have experience of linking the two together (unlikely as the IQ3 is pretty new)? Or at least, any experience of using the extra sensor kits for the AEM EMS? # Can anyone tell me what advantages there would be to having these sensors available to the ECU - more precise maps? Any help much appreciated. Regards, Ben. Link to comment Share on other sites More sharing options...
Wez Posted March 18, 2008 Share Posted March 18, 2008 The racepak IQ3 looks very similar to the AIM MXL dash, I have not seen either hooked up to an AEM although the MXL says it supports it. Link to comment Share on other sites More sharing options...
b.weeks Posted March 18, 2008 Author Share Posted March 18, 2008 Yeah, does look pretty similar from what I can see here: EDIT: Will have to read up on the integration with the AEM. Link to comment Share on other sites More sharing options...
b.weeks Posted March 19, 2008 Author Share Posted March 19, 2008 Tim at Racepak has started a forum post about this should anyone else find this of use: http://www.racepak.com/forums/viewtopic.php?f=4&t=70 Link to comment Share on other sites More sharing options...
