Wazz72 Posted March 16, 2008 Share Posted March 16, 2008 Done some paint work on the car, fineshed putting the clearcoat on. (2K Clearcoat) Just looked and the clearcoat on the sideskirts is a bit thin. Is it ok to put another coat on it in the morning? Link to comment Share on other sites More sharing options...
absz Posted March 16, 2008 Share Posted March 16, 2008 i'll rub it down with some 1500 paper wet/dry just to remove the shine before recoating or there is a possiblty of the clearcoat flaking in the future. Link to comment Share on other sites More sharing options...
Wazz72 Posted March 16, 2008 Author Share Posted March 16, 2008 Wouldnt a grey scotchpad be better? and quicker? Link to comment Share on other sites More sharing options...
absz Posted March 16, 2008 Share Posted March 16, 2008 yeah i guess so:) Link to comment Share on other sites More sharing options...
supra matt Posted March 16, 2008 Share Posted March 16, 2008 yes that will do fine mate Link to comment Share on other sites More sharing options...
Wazz72 Posted March 16, 2008 Author Share Posted March 16, 2008 When putting on the wet coat on a spoiler I got 2 drips (It was hung vertically to spray). What do you find the best way to remove? Scraping with a razor blade then wet and dry, then polish Link to comment Share on other sites More sharing options...
supra matt Posted March 16, 2008 Share Posted March 16, 2008 When putting on the wet coat on a spoiler I got 2 drips (It was hung vertically to spray). What do you find the best way to remove? Scraping with a razor blade then wet and dry, then polish you got it mate but i would leave it a week or two before you do this as it will still be to wet to be that hash with it not unless you sprayed it in a oven then baked it? Link to comment Share on other sites More sharing options...
Wazz72 Posted March 16, 2008 Author Share Posted March 16, 2008 Not oven baked, but the room felt like a bloody oven when i had the heaters running in a paper suit wit a mask on and goggles. put rocket in it to make it go off faster. Link to comment Share on other sites More sharing options...
Harllequin Posted March 16, 2008 Share Posted March 16, 2008 If the clear has not been done in an oven you might want to be vary wary of the thinners in the coat you apply reacting with the coat on the car. If you break its "skin" while sanding, this will be a sure thing and nasty things may well happen. Any time I've had to leave a job till the AM I've just blown the area off with the air line, then applied a "wet coat" to key into the already very soft area, then dusted a few more coats on top. Have to make sure it has flashed very well though. Another thing to take into account any sanding that you do to a clear coat will show through under the layers you apply next. Either way, be very wary of thinners reacting with the paint you have on the car already. Good luck m8. Link to comment Share on other sites More sharing options...
Wazz72 Posted March 17, 2008 Author Share Posted March 17, 2008 So dont sand it, panel wipe it down again, apply a dust coat, and then another wetcoat. The other layers shouldnt be visable underneath then? Link to comment Share on other sites More sharing options...
richard cash Posted March 17, 2008 Share Posted March 17, 2008 ditto on the comment about the thinners. Had more than a few jobs go bad due to reactions because of this. Link to comment Share on other sites More sharing options...
Wazz72 Posted March 17, 2008 Author Share Posted March 17, 2008 Done it this morning, mixed the 2k 2:1 with no thinners and some rocket in it. All went well, I got a couple of drips which i'll sand out later on. Resprayed some dsh panels that were done at the same time, and they went like crazy paving on a few of them, dont know why. I cleaned them exactly the same as the others. I'll have to get the sandpaper back out. Link to comment Share on other sites More sharing options...
Harllequin Posted March 18, 2008 Share Posted March 18, 2008 Congrats on the clear coat. Welcome to the world of paint reacting. At least it was just on the dash If that first skin of dry top coat if damaged in any way it can be a real bugger. One sure fire way of this not happening is to sand them flat again and take off all the paint you applied. Bugger of a job but you will not get a reaction and you can start again. The other method is to sand it flat leaving all your old paint on, coat it with "Barcoat" then start from scratch. I have had to do this a few times on things that have gone bad. Normally after following other peoples previous spray attempts. Hope all goes well for the dash though Link to comment Share on other sites More sharing options...
richard cash Posted March 18, 2008 Share Posted March 18, 2008 even with barcoat ive had reactions. I find spraying it very thinly will create no reactions. Then just use a heatgun to warm up the panel and get all the solvent evapourated. Then add clear and you should be fine. It seems to work for me at least anyway Link to comment Share on other sites More sharing options...
Harllequin Posted March 19, 2008 Share Posted March 19, 2008 Really!! Oh bugger I'll have to watch out for that then. Your the first person I've heard thats had problems with it. I've known it react at the edges of the Barcoat, but never on it Link to comment Share on other sites More sharing options...
richard cash Posted March 19, 2008 Share Posted March 19, 2008 it may have something to do with the terrible conditions i sometimes have to work in :s Link to comment Share on other sites More sharing options...
