Will MAP ecu work with jspec setup?
iaintslow
Yes it will work - you're better with MAP-ECU2 to give you timing control and why would you want to use a GReddy boost cut controller when you have a MAP-ECU/2??? You can already eliminate fuel cut with that as a byproduct of mapping.
MAP ecu2 yes. but i was thinking to get map ecu1, big price difference and i dont really need timing control, iim not planing on big power, just pump gas and 1.2 bar.
Also do jspec have speed limiter?
Thanks
