eyefi Posted July 20, 2002 Share Posted July 20, 2002 i tried for hours, couldnt get to it at all. tried from the top, from underneath, no joy. how the hell do u get to this bleed nut? i ended up just bleeding from the bottom of the rad, that has emptied about 7/8 ltrs, which means there is still a couple of ltrs still in the engine. ta. Link to comment Share on other sites More sharing options...
Supe Posted April 14, 2006 Share Posted April 14, 2006 Hi, everyone, I'm trying to find the Bleed Screw which is supposed to be on the back of the block somewhere, however I just can't see it anywhere. I have looked at the diagrams etc also removed the air intake, turbo heatsheild etc but still can't see the damn thing. I need to completely flush the block and radiator and top up with Toyota Red Coolant. What I am going to do once I find the Bleed valve (with your help ) is open and let everything drain and stick the garden hose into one of the coolant pipes and let it circulate right through everything. Then completely drain it and top up with new coolant and bleed any air that is in the system. Is this correct?, as this is the way I do it on my other cars. Could anyone help please Link to comment Share on other sites More sharing options...
Robert Posted April 14, 2006 Share Posted April 14, 2006 its near the thermostat by the first turbo. Link to comment Share on other sites More sharing options...
Robert Posted April 14, 2006 Share Posted April 14, 2006 bloddy hell just noticed this thread was started in 2002, good lord. Link to comment Share on other sites More sharing options...
Supe Posted April 14, 2006 Share Posted April 14, 2006 Sorry to sound stupid but is there anything that can help me see what the thermostat looks like?. I know where Turbo 1 is and thats about it. Thanks for your previous reply mate as you said the thread was opened in 2002, I done a bit of research through the search before I actually asked rather than being spoonfed . Thanks Link to comment Share on other sites More sharing options...
uk-rich Posted April 14, 2006 Share Posted April 14, 2006 the engine drain screw is not near the thermostat, towards the back of the engine, about 5-6 cylinder postion, about 10 " up from the bottom of the block Link to comment Share on other sites More sharing options...
Supe Posted April 14, 2006 Share Posted April 14, 2006 Right, so is it near the windscreen side or the front side (Front bumper), also what does it look like and is it better to get it from the top or lie underneath the car and try it. Thanks in advance Link to comment Share on other sites More sharing options...
uk-rich Posted April 14, 2006 Share Posted April 14, 2006 not sure i understand your last post, exhaust side of engine, towards the firewall better from underneath, it looks like a bolt head, think its a 14mm not sue tho, it was a while ago i did mine Link to comment Share on other sites More sharing options...
Jake Posted April 14, 2006 Share Posted April 14, 2006 Supe, If you look where the lamda sensor is you should be able to see it. It's the 14mm brass bolthead I'm pointing to in the attached pic Link to comment Share on other sites More sharing options...
