Help. Indicators are flashing too fast!
MaRkYbOy72
Well I have just checked all the indicators and all are working fine in "hazard" mode. I took my car to an auto electrician on Monday and they found a loose wire on the front indicator that is the side that is flashing too fast. They fixed the wire and now the indicator at the front is working fine but just too fast! The other side indicators and hazzards are all flashing at normal speed. Help ... really confused :search:
Hmmmm ... not sure about that ... DO you think its worth buying some different indicator bulbs? Also, i have a big orange bulb and a small white bulb in each side. Is that right? I have the facelift indicators ...
Just take out the ones you have and check them (rears and sides too). If they are LEDs it will be pretty obvious. You can clearly see the filament in normal bulbs.
