Daston Posted February 10, 2008 Share Posted February 10, 2008 Help needed guys I have removed, rear lights, screws under lights, 3 in the centre, 2 upper bolts, 2 nuts at the bottem and scews by the number plate lights. I am having problem getting the bottom 4 screws out 2 of them turn but dont unscrew. Also the sides seem to be still attached to the rear quaters some how Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted February 10, 2008 Share Posted February 10, 2008 under the bumper theres is a rubber strip with 4, these are pop plastic screws, wont unscrew, need to break them out or get a small screw driver and prise the middle up and pull it out, then behind the bumper under the car there are 2 bolts on each side of the quatre inners you can get to lying down, go do it before it gets dark!! Link to comment Share on other sites More sharing options...
Daston Posted February 10, 2008 Author Share Posted February 10, 2008 Cool done the 2 bolts will brake the screws in the morning (got the day off to do car). Shes looking good now one skirt is on fitted like a glove. No pic's till its all done lol Link to comment Share on other sites More sharing options...
Daston Posted February 11, 2008 Author Share Posted February 11, 2008 Got the bottom strip off easy as after trying to pull em out! However the top part is still locked tight. I can pull the bottom out as far as the side clips but the top isnt moving. seems stuck here Link to comment Share on other sites More sharing options...
TRD3000GT Posted February 11, 2008 Share Posted February 11, 2008 there is a strip of bolts that goes all the way up.. you need to go in from under the spat... Link to comment Share on other sites More sharing options...
Daston Posted February 11, 2008 Author Share Posted February 11, 2008 ah cool cheers will get out there after lunch Link to comment Share on other sites More sharing options...
Daston Posted February 12, 2008 Author Share Posted February 12, 2008 Ok still unable to get at these bolts cant even see them from underneath Found my repair manual and found that there are 2 bolts there. Is there any way of getting at them from the inside by removing the boot trim? Link to comment Share on other sites More sharing options...
colsoop Posted February 12, 2008 Share Posted February 12, 2008 Remove the aerial and also the fuel pump ecu, this should give you the access to the bolts. obviosuly the trim pieces need removing first Link to comment Share on other sites More sharing options...
Daston Posted February 12, 2008 Author Share Posted February 12, 2008 cool chers dude thought it may be the tiny japanise hands that I was lacking lol Link to comment Share on other sites More sharing options...
Daston Posted February 13, 2008 Author Share Posted February 13, 2008 You were spot on chap 5 min later its removed! Hope the new one goes on ok and lines up with these 9000000 holes lol Link to comment Share on other sites More sharing options...
