_Shane_ Posted January 29, 2008 Share Posted January 29, 2008 just noticed earlier that these aint lighting up (none light up) Everything in car is running perfect Anyone have a similar problem? could it be a fuse etc thanks shane Link to comment Share on other sites More sharing options...
Kieran Posted January 29, 2008 Share Posted January 29, 2008 Dry joints on the connector probably mate. Only takes 10 minutes to re-solder them. Link to comment Share on other sites More sharing options...
_Shane_ Posted January 29, 2008 Author Share Posted January 29, 2008 cool mate thanks hope thats the problem Link to comment Share on other sites More sharing options...
J_Supra_07 Posted January 30, 2008 Share Posted January 30, 2008 yeh i had same prob when i got mine. 5min fix easy mate. Link to comment Share on other sites More sharing options...
Sparky Posted January 31, 2008 Share Posted January 31, 2008 Yep, I had the same issue. Theres a how to thread somewhere on here! Link to comment Share on other sites More sharing options...
bolarbag Posted January 31, 2008 Share Posted January 31, 2008 Have you tried the 10A fuse under the dash? Link to comment Share on other sites More sharing options...
dangerous brain Posted January 31, 2008 Share Posted January 31, 2008 This really ought to be a sticky in tech (the solution not this exact thread) Its a very prevalent problem and potentially disastrous. You'd be OK as you have an oil pressure guage, others would not be so lucky. Link to comment Share on other sites More sharing options...
_Shane_ Posted January 31, 2008 Author Share Posted January 31, 2008 you would think that mate but my oil pressure gauge stopped workin the other day on me Link to comment Share on other sites More sharing options...
JustGav Posted January 31, 2008 Share Posted January 31, 2008 http://www.mkivsupra.net/vbb/showthread.php?t=115407&highlight=oil+pressure+light Very easy job to do as well. Link to comment Share on other sites More sharing options...
suprab Posted January 31, 2008 Share Posted January 31, 2008 I had to do this too shane.. works fine since Link to comment Share on other sites More sharing options...
_Shane_ Posted February 1, 2008 Author Share Posted February 1, 2008 does the whole dash have to come out to get at this mate ? Link to comment Share on other sites More sharing options...
Kieran Posted February 1, 2008 Share Posted February 1, 2008 does the whole dash have to come out to get at this mate ? Nope, just the sticky-out bit above the dials mate, disconnect the wiring and unscrew the unit from the dash piece. Dead easy. Link to comment Share on other sites More sharing options...
