Blitz DSBC installation question
Chris and Alana
I started fitting this and have everything sorted apart from connecting the solenoid :( I downloaded some instructions but they are not entirely clear. Do you connect one hose onto the pressure outlet of no1 turbo and onto the 'IN' side of the solenoid and then a hose to the top of the wastegate actuator to the 'OUT' side of the solenoid. Do you then cap off the underside of the wategate actuator? Also will the cap have positive pressure on it or a vacuum? And finally, how do you get to the bloody hose, is there somesort of technique or do you have to start stripping bit's to peices to get to it?
