Wez Posted December 30, 2007 Share Posted December 30, 2007 Hey All, How do your brakes feel? My pedal feel is never firm on the first tap of the brakes, if I tap the brakes, let off and then brake hard the pedal is nice and solid. Anyone else experience this? Its not just the first brake of the drive either, each time I brake the initial braking just seems a bit soft and the pedal travels much further, the car stills stops fine but just doesnt feel as good. If I do a quick tap and then brake the pedal travel is minimal and the brakes feel solid which gives much more confidence in braking ability Its like something isnt preasurised until the first tap on the brakes. Link to comment Share on other sites More sharing options...
Wez Posted December 30, 2007 Author Share Posted December 30, 2007 No one? Link to comment Share on other sites More sharing options...
Class One Posted December 30, 2007 Share Posted December 30, 2007 Sounds like you might have some air in your system. Have you tried giving them a bleed? Link to comment Share on other sites More sharing options...
Wez Posted December 30, 2007 Author Share Posted December 30, 2007 Sounds like you might have some air in your system. Have you tried giving them a bleed? Nope not done anything with them. My misses pug 206 does the same thing and I have come across a few cars that do it, just wondered if its normal or not. I would also like to know how to stop it Link to comment Share on other sites More sharing options...
gaz1 Posted December 30, 2007 Share Posted December 30, 2007 i read somwhere that fitting a stiffening brace to the master cylinder help, Link to comment Share on other sites More sharing options...
gaz1 Posted December 30, 2007 Share Posted December 30, 2007 how about one of these, http://www.mkivsupra.net/vbb/showthread.php?t=134883&highlight=carbing post 3 Link to comment Share on other sites More sharing options...
Mike B Posted December 30, 2007 Share Posted December 30, 2007 pad knock; mine did this; it had a tiny warp in the disk, when i had them skimmed the bite became instant again. know what you mean, it's annoying. jack the wheel up and apply the brakes, let them off and turn the whel, see if the brakes are catching anywhere on the disk. Mine did, yet i could not feel any vibration through pedal or wheel when braking hard.. Link to comment Share on other sites More sharing options...
Matt Harwood Posted December 30, 2007 Share Posted December 30, 2007 pad knock; mine did this; it had a tiny warp in the disk, when i had them skimmed the bite became instant again. know what you mean, it's annoying. jack the wheel up and apply the brakes, let them off and turn the whel, see if the brakes are catching anywhere on the disk. Mine did, yet i could not feel any vibration through pedal or wheel when braking hard.. As Mike said, it's the pads being pushed back slightly further due to a disk being less than true. - This is one of the reasons for checking disk runout. I changed all my disks recently and got the runout to as little as I could and the initial bite was superb! Link to comment Share on other sites More sharing options...
Wez Posted December 30, 2007 Author Share Posted December 30, 2007 Thanks guys, I will give this a check. Link to comment Share on other sites More sharing options...
