Chris and Alana Posted December 18, 2007 Share Posted December 18, 2007 Just collecting all the bits I need to install an EBC and after reading this http://www.mkiv.com/techarticles/blitz_dsbc/index.html I need 4 1/4" vacuum cap's to cap off some open ends. Where can I get them from? or what can I use? Thank's Link to comment Share on other sites More sharing options...
Kev.O Posted December 18, 2007 Share Posted December 18, 2007 I ended up using some of the new boost line you need, and putting small caps inside. They were a real tight fit and there was no way it was going to come out. I recall these small caps being something off of a diesel car, though I can't remember what part. I used some 6mm fuel line for the actual hose. HTH Link to comment Share on other sites More sharing options...
DamanC Posted December 19, 2007 Share Posted December 19, 2007 I ended up using some of the new boost line you need, and putting small caps inside. They were a real tight fit and there was no way it was going to come out. I recall these small caps being something off of a diesel car, though I can't remember what part. I used some 6mm fuel line for the actual hose. HTH Diesel injector somethings, cant quite put my finger on it. I used the same. Link to comment Share on other sites More sharing options...
