cossack Posted December 13, 2007 Share Posted December 13, 2007 i thought id be different and try some custom indicators, i thought, car - bike, whats the difference!!! i got a really neat set of 3cm dia, 15 led bike indicators, set one in temp and its flashing about 3 times as fast as the other side with original indicator, the new bulb reads 12v/1w and the original sup one is 12v/21w, im guessing its to do with thw wattage, any views on solution as the indicators look the muts nuts and would love to keep them!?!?!? Link to comment Share on other sites More sharing options...
uk-rich Posted December 13, 2007 Share Posted December 13, 2007 the car thinks there is a bulb out somewhere (due to low power needs of LED's), hence the rapid flashing, you will need a resistor to replace the original load of the bulb Link to comment Share on other sites More sharing options...
cossack Posted December 13, 2007 Author Share Posted December 13, 2007 the car thinks there is a bulb out somewhere (due to low power needs of LED's), hence the rapid flashing, you will need a resistor to replace the original load of the bulb i did think that, just afraid to say incase i made an ahoe of myself which i prob will with the next comment, the last thing i want to do is any harm to the cars loom, so will fittin the resistors f**k anything up and what size should i get? or ive heard of variable resistors, would they be any use and where would i get them?? cheers Link to comment Share on other sites More sharing options...
Tee from China Posted December 15, 2007 Share Posted December 15, 2007 Try Car Builders Solutions the do a special gizmo for when you mix LED's with ordinary bulbs fo fitting them to the rears and not the fronts as well on kit cars Link to comment Share on other sites More sharing options...
Soaruss Posted December 15, 2007 Share Posted December 15, 2007 This is what you need http://www.busters-accessories.co.uk/proddetail.asp?prod=FU6 They should sell them where you bought the indicators from, or most motorcycle shops. Link to comment Share on other sites More sharing options...
heckler Posted December 15, 2007 Share Posted December 15, 2007 or just stick a 5 ohm, 50w resistor across the load. Thats what I do when i do the rear LED conversions Link to comment Share on other sites More sharing options...
