how to fit your stubby conversion
supra steveo
 Share
this is a guide of how to fit your stubby conversion aerial
firstly this is how the oem aerial should look on the car with the mast down
first thing you need to do is remove the locking nut like so , use a hammer and screwdriver with car to undo if tight remembering to hit forward away from car so you dont damage your paintwork
then remove the black rubber grommet, it is very important you do NOT throw this bit away you are going to need it
you then need to remove the boot plastics so you can see the electric motor that makes the mast go up and down
pull out the little drain from the floor
and using a 10mm socket undo the bolt that holds the motor housing to the body of the car
now you can remove the assembly from being fitted to the car
unplug the coax cable that goes to your radio
and unclip the power for the mast motor
you should now be left with the back of the car looking like this
now thats removed get your stubby aerial kit and it should look like this when you add your rubber grommet to the kit
this how the extension bar now goes together
this picture shows the bracket fitted
now the bracket is fitted you should be able to see the top of the bracket i.e. the bit the extension bar goes through
now put the extension bar throught the hole in the car body and the top of the bracket, then fit the large nut to extension bar and tighten, if its a pain to do undo the 10mm bolt at the bottom of the bracket so the extension is free to hang and move so you can get the big nut to bite on the extension bar as soon as the nut is on put the 10mm nut back in to hold the extension bar in place and the nut basically pulls the extension bar in to the car making the grommet seal nicley against the body of the car
now all thats left to do is fit the amplified antenna base to the bottom of the extension bar , now this is where the difference is to the Mk 1. there is now no stress to the fixing on the amplified base , now fit the the inline amplifier that should give an extra bit of boost ( everyone likes boost ) twist the two red wires together and if you run a bit of wire form the IGN live from the back of your stereo to the two red wires that are joined together this should provide enough power to the amplifiers
any dramas PM me
Edited by supra steveo (see edit history)
  • Replies 67
HINTS
* get some wire and either solder or bullet conector it to the red wire then feed it to the ignition power wire behind your stereo , the set up doesnt really need it but if you feel you want to do the job 110% then thats what you can do
* use a little bit of rubber sealant around the where the grommet meets the car ( make sure its out of sight tho ) and where the extension bar meets the top of the grommet
What about the power lead going to the aerial to power that? No good?
I dont have a power meter so cant check to see if that sends 12 volts constantly, if any one does have a power meter and can confirm that it does, and that the negitive not being connected is ok then it should be good to run off that wire too
  • 4 weeks later...
 Share
