Fitted SQQV D/V Hear Whining Noise from Turbo's
max55uk
Hi Guys,
Just fitted the mk2 HKS SQQV Dump Valve to my Twin Turbo 1997 vvti, i have checked all the pipes everything is fitted according to the diagram,
The car boosts normal, no missing, even when its idle its fine.
However i can hear a whining noise when the car boosts. Just wondered if anyone else has had any similar problems?
Cheers
Pics bellow, well the car has an HKS Induction kit and before all you could hear was the Induction Noise but now thats disapeared and instead i'm getting a whiny noise, its not a quite spool on both turbo's, the car has been modded, HKS FMIC, HKS Fcon V, Oil Cooler, Exhaust, Blitz power reader which displayed 370ps @ 140mph and i let go..lol
Might be Uprated Turbo's? as its set to run @1.1 bar boost, i might just get rid of the D/V and back to standard,
Well for one thing you've not fitted the recirc kit which the VVTi requires for the MAF sensor not to get so upset.
If you fit the MAF sensor you won't hear the pssssh much though..
I had one and removed it as the car drives so much better with stock setup.
