supradriver Posted November 12, 2007 Share Posted November 12, 2007 how do you checked the power srearing fluid level? i can only see hot on one side cold on the other Quote Link to comment Share on other sites More sharing options...
Godmutha Posted November 12, 2007 Share Posted November 12, 2007 They are the levels its supposed to be at depending on whether the engine is hot or cold Quote Link to comment Share on other sites More sharing options...
supradriver Posted November 12, 2007 Author Share Posted November 12, 2007 ow right so should it be at the top of it or the bottom (the words hot or cold because its in a little box) Quote Link to comment Share on other sites More sharing options...
Godmutha Posted November 12, 2007 Share Posted November 12, 2007 near to the top but not overfull.... similarly to the oil. If you wipe the stick with a rag, and then put in back in and screw it shut, then take it out again, you'll see what the level's sitting at, then just top up accordingly Quote Link to comment Share on other sites More sharing options...
supradriver Posted November 12, 2007 Author Share Posted November 12, 2007 thanks m8 i have had some well strange noise coming from it now i know its low thanks alot m8 thought it was the pump or somet Quote Link to comment Share on other sites More sharing options...
Steve Posted November 12, 2007 Share Posted November 12, 2007 thanks m8 i have had some well strange noise coming from it now i know its low thanks alot m8 thought it was the pump or somet Probably got some air in the system if you are getting some noises. Top up the fluid, start the car and slowly turn the wheel from lock to lock a few times. That should get the air out. Quote Link to comment Share on other sites More sharing options...
Godmutha Posted November 12, 2007 Share Posted November 12, 2007 No worries If it keeps making the grinding noise and the steering goes heavy, check under the car for leaks.... If you do have a leak, let me know as I can help. Hopefully though, it will just be low on fluid Quote Link to comment Share on other sites More sharing options...
supradriver Posted November 12, 2007 Author Share Posted November 12, 2007 i will give it ago when i get some fluid tomorrow any idea how much its gonna be Quote Link to comment Share on other sites More sharing options...
supradriver Posted November 12, 2007 Author Share Posted November 12, 2007 theres no difference in driving its not heavy or anything just makes a lot of noise Quote Link to comment Share on other sites More sharing options...
Godmutha Posted November 12, 2007 Share Posted November 12, 2007 Prob £15 for a bottle of decent fluid (not the halfrauds crap) Quote Link to comment Share on other sites More sharing options...
supradriver Posted November 12, 2007 Author Share Posted November 12, 2007 thanks m8 i will get the good stuff:) hope the noise will go when i first heard it i thought that sounds expensive. Quote Link to comment Share on other sites More sharing options...
supradriver Posted November 13, 2007 Author Share Posted November 13, 2007 i still have a noise its not as bad as it was does it natural have a noise i dont remember lol Quote Link to comment Share on other sites More sharing options...
Godmutha Posted November 13, 2007 Share Posted November 13, 2007 it should wear off.... if the fluid level was low for a while, it will take a little time to get back through the system completely..... give it a day or so Quote Link to comment Share on other sites More sharing options...
supradriver Posted November 13, 2007 Author Share Posted November 13, 2007 ok will do. hope it does. i shall see what will happen Quote Link to comment Share on other sites More sharing options...
Godmutha Posted November 13, 2007 Share Posted November 13, 2007 ok will do. hope it does. i shall see what will happen Let me know if you still have trouble... i aren't too far away from you Quote Link to comment Share on other sites More sharing options...
juanchan Posted November 13, 2007 Share Posted November 13, 2007 I had a major power steering leak back in the summer. After fixing it and topping it up with fluid, it took quite a while for all the odd noises the pump was making to stop. It should improve over time, providing you haven't got a big leak. Quote Link to comment Share on other sites More sharing options...
