DannoSupra Posted September 16, 2007 Share Posted September 16, 2007 Is it due to the fact of my decat being over 3" at the flange where it connects to the down pipe? When it got made, i noticed the flange made had a bigger internal diameter than the 1st cat that came off... If i were to take it off and inspect further... What's the diameter suppose to be? Its a UK so no need for restricor ring no? Cheers Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 anyone? Quote Link to comment Share on other sites More sharing options...
SupraJames Posted September 17, 2007 Share Posted September 17, 2007 Thats quite a spike..! Mine is UK and fully decatted, cant remember flange size, but never had anything quite like that. Do you have a boost controller..? Quote Link to comment Share on other sites More sharing options...
Ric Posted September 17, 2007 Share Posted September 17, 2007 Even if fully decatted a UK spec shouldnt go over 1.0 bar due to wastegate size or control or somthing like that. Perhaps a faulty wastegate/actuator maybe Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 yeah i got a Apexi AVC'R... Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 17, 2007 Share Posted September 17, 2007 yeah i got a Apexi AVC'R... Turn the gain down;) Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 Turn the gain down;) is it worth me sorting the xhaust tho? Might take is somewhere to get set up properly, any recomandations? Quote Link to comment Share on other sites More sharing options...
Chris and Alana Posted September 17, 2007 Share Posted September 17, 2007 Like said before, the UK spec has a wategate that is actually up for the job (unlike the j-spec) so I dont think it would be worth the expense of fiddling with the exhaust as it is more than likely going to be something else that is causing the boost spike. Again someone mentioned it could be a faulty actuator or maybe a vsv. Again it may be due to the settings on the EBC. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 its only doing it since putting the zorst on, thats why i thought it was related anyone recomend where to take it, or diy setting up cheers Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 17, 2007 Share Posted September 17, 2007 its only doing it since putting the zorst on, thats why i thought it was related anyone recomend where to take it, or diy setting up cheers Yes changing the exhaust will of had an effect, so you will need to change the boost controller settings. Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 17, 2007 Share Posted September 17, 2007 As has already been said, adjust the gain to a lower figure to stop the spool up getting out of control and causing the spike. Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 As has already been said, adjust the gain to a lower figure to stop the spool up getting out of control and causing the spike. I'll have a go at it tonight. Has anyone got a copy of the plumbing to do with vacuum vsv bypassing etc to install AVC'R. I've lost mine, i just want to double check everything is ok All i've done with the avc'r is, set it to auto setup. But i got it off all of the time maxing at 1.0Bar, but with it on, its bewteen 1.4 - 1.5 Max The wiring is ok, i made sure the right earth went on the right way on ecu, because there's 2 earths to go on one wire isnt there Cheers for all the info though guys, i might make a gasket/restrictor out of 3" pipe with a flange (making sure the gases escaping go through 3" gap only) and just slot it into the exhaust and use it as a gasket too. If that makes sence to ya'll :thumbs: Quote Link to comment Share on other sites More sharing options...
Marty Posted September 17, 2007 Share Posted September 17, 2007 here... http://www.mkiv.com/techarticles/index.html Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 Cheers fella, i cant remember anything about having to cap that Actuator Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 17, 2007 Share Posted September 17, 2007 I might be wrong but you shouldn't use auto modes on sequential turbo setups... Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted September 17, 2007 Author Share Posted September 17, 2007 Sorted Setting 'A' is now 1.14Bar @ 50% Duty Setting 'B' is now 1.22Bar @ 62% Duty But showing 'B' as 1.3Bar on the Defi's Did all that in 'Manu' in 3rd with TC on !!! Scary on dual carrageway Which one do i take refference off for Boost, Defi's or AVC'R? Quote Link to comment Share on other sites More sharing options...
