Torque Convertor Damage
T2 MSW
RobSheffield and I were fitting my Nur spec last weekend and rob pointed out some damage on the back of the torque convertor, nether of us were sure if this was a major issue or not. Looking for some input on this issue to guage if its repairable or if I need to replace the convertor?
Its looks worse than it is in the pics but there is a definate hole aprox 5mm across. Its right on the natural curve of the convertor.
I'd replace it. As I understand it, torque converters work through centrifugally forced fluid transfer through vanes inside - that damage could interfere with that and I suspect it'd be unbalanced being potentially damaging to the transmission.
Cheers,
Brian.
errrr, that's not a torque converter.
Its the gearbox bell housing, isn't it?
:yeahthat: Teach me to pay attention to the pics - it is indeed the autobox bellhousing. Has whatever took that chunk out of it penetrated through and damaged the TC inside?
Cheers,
Brian.
no expert but that seems really wierd, trying to think how something like that could occur?
Going by the pics you can see the autobox sump and the exhaust downpipe along with the auto fluid cooler pipes so the damage is at the part most exposed to the road - a great big rock chucked up by the front wheels at speed might be enough to do it or by bottoming out the car on a speed hump or something at that point, like those ones you get that only take up the middle part of a lane and you're always tempted to straddle them.
Cheers,
Brian.
Not sure what has cause the damage and I have not hit anything so I can only assume it was done before I bought the car.
Ah ok did not realise it was the bell housing my bad. Not sure if anything has been damanged internally but im thinking this is why the gear changes are lumpy and that the gear oil I have ordered is not going to resolve that issue?
