short block -CP/carillo etc
Chiefgroover
OK folks here it is
Short motor 86.5mm bore, no step on block with CP pistons
Lightened/bladed/balanced crank with T77 bearings.
Carillo H rods
modded oil pump
Has a fault. #6 has a slightly oval bore, so as you can probably guess the piston skirts scratched when it got a proper heating up. Compression on #6 was still 150 when removed however there was a piston knock sound. The bore is fine at the top but small damage you can feel with your finger nail at the bottom of the bore, the rest is like new.
I may split it, but want to see if anyone is interested complete first.
Matt I am trying to figure out a price but its frying my head. I know what the rods/pistons/bearings etc cost new but with crank and block complete allowing for someone to sort it I really dont know at this point. If I come up with a figure i'll let you know asap. I want a decent price, but at the same time I dont want to over charge anyone either :)
