Indicators...so irritating
Guest Tylos
Hey guys, got another question for you all.
Was driving the other day tried to indicate left and fumbled the stick. Now whats really irritating me is that whenever i indicate right its normal however when i indicate left it flashes about 3 times the normal speed (both on the dash and externally). Any of you guys had this before or know how to set it back to normal speed?
Cheers in advance.
P.S. Just to follow up with the roof (in a previous post i said my Aerotop roof had become stuck on). Took this to my dads friends garage they managed to get the bolt out in the end without drilling, required undoing and doing the bolt back up for around 15 minutes. They then ran a chaser up it to rethread it a bit so it kinda works although it needs replacing (it became cross threaded when i put the roof on and this knackered the bolt), but if anyone has the same problem try that (they had to use a much bigger allen key thing than i keep in my car!)
