Elmo Posted September 2, 2007 Share Posted September 2, 2007 Getting annoying wind noise after replacing the window mechanism which is really getting on my nerves so looking for a pair of wind deflectors. Cheers! Link to comment Share on other sites More sharing options...
Ewen Posted September 2, 2007 Share Posted September 2, 2007 The noise could probably be sorted by window adjustment ? Unless you really want the deflectors obviously:) Link to comment Share on other sites More sharing options...
Elmo Posted September 2, 2007 Author Share Posted September 2, 2007 The noise could probably be sorted by window adjustment ? Unless you really want the deflectors obviously:) I have spent hours trying to adjust the windows, the door card has been off more times than I can remember, I'm now an expert on the removal and fitting of door cards! So I've given up mate, just can't get it right I thought wind deflectors might be an alternative solution. Link to comment Share on other sites More sharing options...
Ewen Posted September 2, 2007 Share Posted September 2, 2007 I feel your pain,,,I had problems too after replacing mine, although I got there eventually. You played with the in-out adjuster at the bottom too ? Sorry for messing up your post btw:) Link to comment Share on other sites More sharing options...
Elmo Posted September 2, 2007 Author Share Posted September 2, 2007 I feel your pain,,,I had problems too after replacing mine, although I got there eventually. You played with the in-out adjuster at the bottom too ? Sorry for messing up your post btw:) I have played with the adjuster but it's doesn't seem to make much if any difference. I'm actually quite proud of myself as I have restrained my self from smashing anything with a hammer Link to comment Share on other sites More sharing options...
Nic Posted September 2, 2007 Share Posted September 2, 2007 I can supply new one if needed. Link to comment Share on other sites More sharing options...
