cheekymonkey Posted May 7, 2007 Share Posted May 7, 2007 Guys, If I was to go down the route of either totally disabling the stock traction control or fitting RLTC, can the Trac ECU box in the passenger footwell be removed to make more room down there? There seems to be a lot of gubbins for Trac given that the consensus is that it doesn't really work all that well! James Link to comment Share on other sites More sharing options...
Steve Posted May 7, 2007 Share Posted May 7, 2007 I have RLTC, so i have just unplugged the TRAC ECU with no issues. Link to comment Share on other sites More sharing options...
cheekymonkey Posted May 7, 2007 Author Share Posted May 7, 2007 I have RLTC, so i have just unplugged the TRAC ECU with no issues. On a related note - does the RLTC install just involve wiring things into the ECU harness? If so I could probably install it myself Link to comment Share on other sites More sharing options...
Steve Posted May 7, 2007 Share Posted May 7, 2007 The RLTC is connected into wires behind the dash board i think. Link to comment Share on other sites More sharing options...
Steve Posted May 7, 2007 Share Posted May 7, 2007 http://mkiv.com/techarticles/racelogic_Install/index.html Link to comment Share on other sites More sharing options...
TrickTT Posted May 7, 2007 Share Posted May 7, 2007 If you have an auto removing the trac ecu can cause gearbox issues as it uses the trac butterfly to reduce power on upchanges. To fit the rltc, there are the 12 injector wires, plus power and rpm input to be wired into the main ecu, and 4 abs wires to the abs ecu behind/under the stereo. Link to comment Share on other sites More sharing options...
