Rear nearside hub assembly including bearing
suprattgaz
I have the full rear hub assebly that I have swapped out of mine. Actual hub and bearing has only done 3000 miles, but for some reason the bearing started squeaking after a long run. Bearing seems to run ok and is not dry. Anyway instead of mucking about with it I just got a whole new assembly and swapped it out. Also comes with ABS sensor etc.
I travel South coast quite a bit with work so could drop off if required.
Gary
