Claying the car - what to use?
ChrisSZ
Gonna have to have a go at this very shortly - do I just need to buy a clay bar or are there other bits required? Will mildly soapy water do as a lubricant (for the clay) or should I use something else?
All (sensible, relevant) advice appreciated :D :d
I use the Meguires pack - all came together nice and easy.
same here too. Works well.
It comes with detailing spray, but you could use soapy water, i.e. water with car shapoo as per washing the car.
always keep the area well lubracted or it tends to stick and possibly mark the paint slightly.
always turn the clay (or use fresh) to avoid rubbing grit etc on your paint
easy job though and satisfying if it needs doing, makes the paint feel nice and smooth and it gets a good shine once polished/waxed :)
I got the Meguires kit yesterday with 3 bars...:D I had a go on a small bit of my bonnet but I don't feel it has made much of a difference to be honest.
If I look in the light I can still see swirl marks. Granted it is a bit better than the bits I have not been done but it's nothing to write home about...:rolleyes:
I am going to do the whole car over the weekend and see how it fairs....;)
H.
H.
The clay bar isn't intended to remove swirl marks ;) It's intended for the bonded on contaminants that an ordinary wash won't shift.
Meguairs do a tube of stuff called Swirl X, really good for removing swirls in paint, mine came up a treat. Never going to be perfect finish unless you power mop with differing grades of cutting compound and a lot of hard work.
As for Fairy on cars, I was advised by a pro valeter never to use any sort of washing up liquid on paint as it contains lots of nasty chemicals which although are great for getting burnt on sheppards pie off your pots are really not nice to paintwork.
Another tip that most of you prob know already is never polish or wax Carbon Fibre, bonnets, wings etc etc, makes them go very dull over time.
yus, did you get a PC in the end michael?
ive got hold of a angle grinder this weekend, got some polishing pads etc gonna give mine a good swirl removal day :)
um...swirl removal with an angle grinder? That wont work mate, you will add more. You want a PC without a doubt.
