dini_the_owl Posted April 9, 2007 Share Posted April 9, 2007 I managed to get the engine started this weekend after months of rebuild, anyhow yesterday after about ten minutes of running ok the Power steering pump started making like a rumbling sound so i knocked off the engine and the Fluid was frothing quite badly, toped it up to the correct level again and tried locking the steering over a few of times to relieve any air that may have got in the system and i find i cannot get rid of the air bubbles,if i start the engine and everytime pump rumbles like mad,fluid frothes and gushes out of the res?????? tried bleeding them several times but the same happens and pump never stops rumbling with engine on, i am using dextron 2 fluid as it is recommended for the system, i have changed the o ring on the pump input which i feel confident arn't leaking and made sure piping is ok which it is. any help would be appreciative starting to think pump is gone???[sAD][/sAD] FYI the steering feels ok and is not notchy or anything like that? Quote Link to comment Share on other sites More sharing options...
Nic Posted April 9, 2007 Share Posted April 9, 2007 My car was stood for around 5 months and I now have the same problem. If you can't get rid of the groaning noise after bleeding the system (full lock a few times from side to side with cap off), then sounds like your pump is shot. I've just ordered a new pump for mine. Quote Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted April 9, 2007 Share Posted April 9, 2007 Often the frothing is just an air lock. Run it with the lid off the reservoir for a while(just sit it on the top if frothing). If that dont work try turning the wheel a quite a bit. There is a way of piercing the filters inside with a pin to cure it. Jody T is a good person to ask by experience. Good luck. Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted April 9, 2007 Author Share Posted April 9, 2007 Thanks for the reply guys,One thing is i have used my n/a pump for the conversion which was working ok prior to this and just bought the union and o ring for a tt, res was purchased s/h but was cleaned out well before re using and ive blown through it and seems ok, there seems somehow to be pressure coming from somewhere because when the car is started with the cap off the fluid is gushing out of the top of the res and i mean gushing???? another thing is, even with the res topped up the pump still is rumbling which i thought would go, i started earlier for about 15 seconds with the cap on and when i took it off the fluid looked like a bottle of coke which had been shaken for 5 mins... Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted April 9, 2007 Share Posted April 9, 2007 How old is the fluid? old fluid takes out pumps racks etc at will !. Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted April 10, 2007 Author Share Posted April 10, 2007 Fluid was changed after the initial install of the motor? how can air be getting into the system so bad as i cannot see any fluid leaks? Quote Link to comment Share on other sites More sharing options...
alan_blue Posted May 6, 2007 Share Posted May 6, 2007 can we have mre infor on this filter blocking issue please? would it caose frothing if blocked?? Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 10, 2008 Share Posted February 10, 2008 Thanks for the reply guys,One thing is i have used my n/a pump for the conversion which was working ok prior to this and just bought the union and o ring for a tt, res was purchased s/h but was cleaned out well before re using and ive blown through it and seems ok, there seems somehow to be pressure coming from somewhere because when the car is started with the cap off the fluid is gushing out of the top of the res and i mean gushing???? another thing is, even with the res topped up the pump still is rumbling which i thought would go, i started earlier for about 15 seconds with the cap on and when i took it off the fluid looked like a bottle of coke which had been shaken for 5 mins... Having the same problems as this with mine, did you find a solutioin in the end? i have put new oil in and tryed bleeding it for ages but like above its seems to be dragging air in from somewhere Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 10, 2008 Share Posted February 10, 2008 Found the problem in the end after a few more searches on here, turned out to be the oring on the delivery tube baked that was making it drag air in. Quote Link to comment Share on other sites More sharing options...
