jaymdee Posted July 2, 2006 Share Posted July 2, 2006 I have just had some new Toyo Proxy T1R's fitted to the rear of the car and now the handling feels all weird at the back end when throwing the car round corners at speed. It seems to pitch & roll far too much (it's never done this before). Anyone else had this with these tyres? I'm going to try to get Toyota to do 4 wheel alignment, but I know my rear camber adjusters are seized, so not sure how successful that wil be. Could it be the reinforced side wall reacting differently to the Michelin's? cheers for any suggestions J Link to comment Share on other sites More sharing options...
markrzs Posted July 2, 2006 Share Posted July 2, 2006 Apparently you need to run tyres in for approx 500mls, this lets them ''scrub'' a bit. It's all due to the silicone type stuff they use when making the tyre in the mould. If your alignment was ok before it should still be ok now, i don't think changing tyres makes a difference unless you have gone for either to larger or smallerl tyres. ? Mark Link to comment Share on other sites More sharing options...
Jezz Posted July 2, 2006 Share Posted July 2, 2006 I've got these on my integra. After a few hundred miles they sort themselves out. Real good tyre! Unbelievable grip and wear really well. May put a set on my supra when it comes back. Link to comment Share on other sites More sharing options...
Steve Posted July 2, 2006 Share Posted July 2, 2006 Have these on my car, once they wear in they awesome Link to comment Share on other sites More sharing options...
jaymdee Posted July 2, 2006 Author Share Posted July 2, 2006 Thanks Guys, So basically after a few hundred miles the car may feel as it was again. I know tyres need to be scrubbed in a bit, but I've never really noticed it much before. cheers J Link to comment Share on other sites More sharing options...
sarjo Posted July 2, 2006 Share Posted July 2, 2006 I could always borrow them and give them back to you 'worn in' if you'd prefer Link to comment Share on other sites More sharing options...
Guest mk47 Posted July 2, 2006 Share Posted July 2, 2006 i just got some new tyres for the rears yesterday and was playing up drive wise, although i was told that to give it 100-200 miles to settle in. ive sucessfully completed 200 miles since then and they are great. Link to comment Share on other sites More sharing options...
jaymdee Posted July 3, 2006 Author Share Posted July 3, 2006 I could always borrow them and give them back to you 'worn in' if you'd prefer Ha Ha Link to comment Share on other sites More sharing options...
miko_supra Posted July 3, 2006 Share Posted July 3, 2006 yeah had these on my fiesta, good tyres and lasted a pretty good long time aswell Link to comment Share on other sites More sharing options...
Thorin Posted July 3, 2006 Share Posted July 3, 2006 A nice big burn out should scrub them in pretty quick Link to comment Share on other sites More sharing options...
Guest rabskyline Posted July 3, 2006 Share Posted July 3, 2006 anyone had a new rear bike tyre fitted ?? its the same ! it feels wooly and your confidence goes until you get that shiny surface down a bit and get used to the different tyres ! they are top notch rubber ! but i suppose its like changing your shoes ! Link to comment Share on other sites More sharing options...
Nic Posted July 3, 2006 Share Posted July 3, 2006 Have you checked the tyre pressures? Might be worth experimenting with them and seeing if it improves things. Link to comment Share on other sites More sharing options...
imi Posted July 4, 2006 Share Posted July 4, 2006 I have just had some new Toyo Proxy T1R's fitted to the rear of the car and now the handling feels all weird at the back end when throwing the car round corners at speed. It seems to pitch & roll far too much (it's never done this before). Anyone else had this with these tyres? J Had these on the rear of My supra, no complaints with Grip.....and they lasted 21K miles and I am sure you agree that that is a lifetime.. I now have Eagle F1s on the rear, will see how these wear....and btw: still Toyos in the front...upto about 24K miles now Link to comment Share on other sites More sharing options...
Ian C Posted July 4, 2006 Share Posted July 4, 2006 My Pirelli's feel fine from the word go, although they have a lot less grip for about 10 miles, can't believe some tyres take 200 to 500 miles to sort out but then I've only ever used Pirelli's -Ian Link to comment Share on other sites More sharing options...
jaymdee Posted July 4, 2006 Author Share Posted July 4, 2006 Have you checked the tyre pressures? Might be worth experimenting with them and seeing if it improves things. Yes Nic. Had them set to 34 when put on. I then reduced them to 32 and it felt a bit better. I'll give a week or so and see how they feel. cheers. I must say I liked the Michelin Sport Pilots I had last time, but only got 7500 miles from them !!! J Link to comment Share on other sites More sharing options...
lockys96 Posted July 4, 2006 Share Posted July 4, 2006 or you could pull aside. and do a big burn out. that will wear them in instintly Link to comment Share on other sites More sharing options...
Shovels Posted July 5, 2006 Share Posted July 5, 2006 I've just had Eagle F1's fitted - same thing - feels like the back end is 'loose' - not nice at all! I'm hoping they're going to wear in soon. Link to comment Share on other sites More sharing options...
