gaz1 Posted July 1, 2006 Share Posted July 1, 2006 this comes up on my pc a few times now, a problem has been detected and windows has been shut down to protect your computer. if this is the first time you have seen this error restart your computer, if this screen appeazrs again follow these steps. check to make sure you have adequate disk space, if a driver is identified in this message disable driver, or check video adapters, check with hardware vendor for bios updates disable bios memory options such as cashing or shadowing, if you need to use safe mode to remove or disable components restart computer, press f8 and use advanced start up options then select safe mode. technical information stop: oxoooooo8e(oxc0000005,oxf76852cc,oxf78f6990,0x00000000) mp firewall,sys-adress f76852cc base at f7683000, date stamp 3 dfoc071 begining dump of physical memory, physical dump complete. omg what is this my pc has tons of hard drive space on it Link to comment Share on other sites More sharing options...
colsoop Posted July 1, 2006 Share Posted July 1, 2006 Are you running Mcafee personal firewall ? if so a quick search of google with that error message points to Mcafee check the search results HERE Link to comment Share on other sites More sharing options...
