Chiselling with a power drill?
Ark
Does anyone know if you can get a drill bit that actually a chisel?
I need to cut a small channel in a concrete floor to lay down a telephone cable, and if I try doing that with a cold chisel and a hammer, it'll take until June 2007!! So, can I get a chisel kind of attachment thingy for my hammer drill? If so, what's it called, and where can I get one?
ta
angle grinders the best thing to use with a small stone cutting disk, just done the same thing at mine but with network cables. cheap ones only cost £20 from B&Q.
yeah good point, even if you do go down the chisel route you will have to cut the sides of the channel with a grinder first anyway.
better bet go to hire place get a 9" grinder with a diamond disc, that will cut about 3"inch deep, wear a face mask and goggles, cut the 2 lines, then hammer and bolster dead easy mate:d
Yeah, and don't forget to hire an industrial hoover and to put aside a few days to clean up after as this will throw sh*t everywhere. Unless of course it's outside or the mess don't matter?
Paul
