lockys96 Posted June 28, 2006 Share Posted June 28, 2006 this is pissing me off, days it seems to be fine. others like today the boosting of the car seems to be all over the shop. once i boot it, the boost comes on, then stops, comes on, stops, comes on etc. makes ure head go back and forward. lol sometimes it feels like boost delay, what is likely to be the problem. i just want my car to be on the button every time taa lads:( Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 bump Link to comment Share on other sites More sharing options...
Alex Posted June 29, 2006 Share Posted June 29, 2006 How is your boost controlled? Do you have an FCD? Do you have cats? Do you have a restrictor? Which plugs are you using? What are they gapped to? Have you tested your EGCV? Does the second turbo fail to come in or come in late? Link to comment Share on other sites More sharing options...
Lucifer Posted June 29, 2006 Share Posted June 29, 2006 DEFO check your Wastegate VSV for iar leaks. Link to comment Share on other sites More sharing options...
Suprasteve Posted June 29, 2006 Share Posted June 29, 2006 this is pissing me off, days it seems to be fine. others like today the boosting of the car seems to be all over the shop. once i boot it, the boost comes on, then stops, comes on, stops, comes on etc. makes ure head go back and forward. lol sometimes it feels like boost delay, what is likely to be the problem. i just want my car to be on the button every time taa lads:( mine sometimes does this in 6th gear between 2,000 - 4,000 rpm. the boost gently bounces up and down between 0.6 - 0.8 bar but once the 2nd tubbie kicks in its fine (mind you i very rarely get to 4k rpm in 6th !!!) and very occationally if i drop down a few cogs on the gearbox and raise the rpm above 4,000 rpm the 2nd tubbie sometime doesn't kick in especially 1st and 2nd gear. are they similar problems to yours ? Link to comment Share on other sites More sharing options...
Lucifer Posted June 29, 2006 Share Posted June 29, 2006 Do you guys have a boost controller? AS that sounds like a dodgey install. Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 How is your boost controlled? Do you have an FCD? Do you have cats? Do you have a restrictor? Which plugs are you using? What are they gapped to? Have you tested your EGCV? Does the second turbo fail to come in or come in late? no FCD. Yes both CATS no restrictor Plugs, god knows gapped to? egcv? Not really sure there, i hope it comes in..... Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 DEFO check your Wastegate VSV for iar leaks. what do i have to take off to look at that, im not very technical Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 i may as well buy new plugs. which ones. Link to comment Share on other sites More sharing options...
Suprasteve Posted June 29, 2006 Share Posted June 29, 2006 Do you guys have a boost controller? AS that sounds like a dodgey install. i do have a boost controller but it does it without it too (not as noticable tho) Link to comment Share on other sites More sharing options...
ardasaliah Posted June 29, 2006 Share Posted June 29, 2006 DOes it feel like a miss fire? Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 it feels like the boost is on and off. the boost doesnt come online smoothly. Link to comment Share on other sites More sharing options...
Alex Posted June 29, 2006 Share Posted June 29, 2006 "boost is on off" That's not really helping much mate...try some specifics....like how quickly. Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 i mean like the boost seems to be delayed sometimes, and when it comes on, its not smooth, its jerky and by boost on off, i mean from when in second gear and giving it some beans it from booting it upto 7,000rpm and chaging gear to 3rd, the boost very sharply and quickly is on and off, i.e you feel the turbo kick in, then stop, kick in all the way up to changing to 3rd gear Link to comment Share on other sites More sharing options...
Alex Posted June 29, 2006 Share Posted June 29, 2006 Sounds like your plugs are shot NGK BKR7E's should sort it out... Worst case your coil packs are breaking down....but I expect it's your plugs. Link to comment Share on other sites More sharing options...
ardasaliah Posted June 29, 2006 Share Posted June 29, 2006 Sounds like a misfire- That would cause boost to drop off. If so then change your plugs. Link to comment Share on other sites More sharing options...
Lucifer Posted June 29, 2006 Share Posted June 29, 2006 Got to be VSV surley. Link to comment Share on other sites More sharing options...
ardasaliah Posted June 29, 2006 Share Posted June 29, 2006 Got to be VSV surley. possible. My car use to do this when my plugs were shot. every time I booted - boost would build -I would then have a miss fire- causing the boost pressure to drop. then the boost would build- miss fire- boost back down again. Changed plugs which sorted Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 might as well change my plugs anyway, which ones would you recomend plus what is VSV martin? Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 dunno what VSV means but i have checked all the vac lines coming off and around the turbos. all look fine to me. So prob need new plugs Link to comment Share on other sites More sharing options...
Lucifer Posted June 29, 2006 Share Posted June 29, 2006 I just cant see that. Unless the revs are not smooth too. Just cant see it. Link to comment Share on other sites More sharing options...
Alex Posted June 29, 2006 Share Posted June 29, 2006 If it stutters whilst accelerating it's an ignition issue. I've given you the name of the plugs in post 15. Link to comment Share on other sites More sharing options...
lockys96 Posted June 29, 2006 Author Share Posted June 29, 2006 so its NGK BKR7E's with 0.9 gap hope its not coil pack Link to comment Share on other sites More sharing options...
lockys96 Posted July 6, 2006 Author Share Posted July 6, 2006 still getting boost stutter, but id like to add boosting in first is pathetic.. feels more like a N/A in first. anyways, its booked in at toyoda-tech on monday, having fuel filter, oil filter, diff/engine/gearbox oil, coolant, brake fluid, spark plugs changed basically a B service i think. should i ask them to check anything?, i.e the problems im having. Link to comment Share on other sites More sharing options...
Swampy442 Posted July 6, 2006 Share Posted July 6, 2006 Tell the garage, might cost more but you'll get it sorted (hopefully!) Link to comment Share on other sites More sharing options...
