Guest timsmr2 Posted June 27, 2006 Share Posted June 27, 2006 Hi all, Sure this will be really simple for you I dont actually have a supra as my username may suggest. Anyway I'm fitting a new turbo that will have a 4"/100mm intake pipe and was wondering if your Supra's had the same size intake so i can order an appropriate air filter cone. TIA Tim Link to comment Share on other sites More sharing options...
paul mac Posted June 28, 2006 Share Posted June 28, 2006 my we are a helpful lot today aren't we, i use a RE-0870 K & N on a 4" intake tube Link to comment Share on other sites More sharing options...
Guest timsmr2 Posted June 28, 2006 Share Posted June 28, 2006 my we are a helpful lot today aren't we, i use a RE-0870 K & N on a 4" intake tube Cheers Paul you've been a great help is that a standard intake tube size or is yours different cause you using a T61 only ask as I was thinking about using an Apexi power intake as I have used before and wondered if the supra one would fit a 4" intake Cheers Tim Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2006 Share Posted June 28, 2006 If you're talking about the 'standard' Supra version of the Apexi power intake then it's no-where near 4inch, more like 2.5. Its tiny in comparison to the K&N 4inch intake used on the single turbo cars, which I think Paul Mac was referring too Link to comment Share on other sites More sharing options...
Guest timsmr2 Posted June 28, 2006 Share Posted June 28, 2006 So the K&N is the way forward. Cheers Tim Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2006 Share Posted June 28, 2006 For a cone filter you can't get much bigger than a RE-0870 Link to comment Share on other sites More sharing options...
