FOUND 2JZ GE power steering
shervin_ice
 Share
15 minutes ago, shervin_ice said:
Nothing wrong with my TT power steering as im going with after market inlet manifold so i was thinking maybe I should change it to Ge power steering instead
The pumps are the same. The reservoirs are different.
I swapped my NA rest over to TT so i have a NA res you can bolt to the pump if needed. Easy to do
I switched to the NA reservoir when I went to an aftermarket inlet, but the return hose spigot clashed slightly with the manifold, so I had the reservoir modified.  Just something to be aware incase in case you get the same issue.
Oh i see what you mean okay i’ll try to see how it fits first  if not i’ll see what i need to do after and thanks for your input  😉
  • shervin_ice changed the title to FOUND 2JZ GE power steering
 Share
