Alternator - Twin Turbo 1993 J-Spec
kurkjones
 Share
Hi all,
Relatively new to the forum and looking for advice/to purchase a new alternator for said Supra. Mine is only charging the battery when revving over 2k rpm.
OEM Number = 2706046120
When put into Autodoc, it showed 12v x 100A alternators. Just saying this incase anyone knows different!
Any good brands to go for?
Thanks
Kurk
Thanks @keron. I'll take a look. It was the verdict of the AA after I took it a drive and then switched car off, it wouldn't start up again. They came out and had a multimeter on car and had me rev. Said it was maybe half the brushes inside had become ineffective.
do the tip ex test on the crank pulley... put a paint line across the face of it, after running it a couple times on the spot, see if the line splits..... very common.... sounds like this really as the aux belt doesnt catch if the pulley has split....
  • Like 2
 Share
