Crash Bandicoot Posted June 27 Share Posted June 27 (edited) Uk spec with the usual Uk refinements: Bonnet scoop Engine EGR system Real leather front and rear seats Heated front seats Glass headlamps Etc. Matching engine/frame numbers Engine stripped and rebuilt/forged less than 5k miles ago. Runs like a dream. Originally auto, which has been replaced with a PMC kit mated with a BMW M3 6 speed gearbox. Been recently fully restored on the underside Was resprayed in original paint code prior to wrap. Wrap is matt black (slight metallic dark grey tint) wrap has been on a while now and is showing in areas. If I was keeping I’d have it rewrapped personally, I see it as a good protection for now, still presentable. Engine/exhaust: Block bored to 86.5mm, honed and decked Forged Manley pistons Full ACL bearings King thrust washers Head skimmed and pressure tested Valves reground New stem seals Following rebuild parts new oem: Full gasket set Water pump Oil pump Crank pulley Aux tensioner AEM 4” intake GREDDY intercooler kit BOOST LOGIC manifold ceramic coated T67 gen2 BB Precision turbo Heat blanket HKS bov HKS 50mm external waste gate Stainless downpipe and cat back Stainless cat back system Fuel/management: WALBRO 485 fuel pump AEROMOTIVE fuel pressure regulator DENSO 850cc injectors LINK G4 ecu with map selection switch BOOSTLOGIC traction/launch control Transmission: GETRAG 420g gearbox conversion Latest PMC adopt or plate and billet flywheel SPEC stage 3+ clutch kit Bailey one piece driveshaft Genuine clutch and brake pedals Genuine new gear surround TRD gear knob Uk spec big case LSD with cooler Cooling: Fluidine radiator Polished upper rad pipe and water neck Alloy expansion tank Suspension: TEIN Superstreet coilovers Front strut brace Brakes: KSPORT 8 pot front calipers KSPORT 360mm front bells/rotors Oem Uk spec rear calipers New OEM rear discs HEL braided brake lines all round Wheels/tyres: YOMOHAMA 18” Advan RS wheels Front 9j 245/40/18 pilot sports Rear 10j 295/35/18 pilot super sports Interior: MOMO Nero alcantara steering wheel TRD dash faces (not genuine) GREEDY boost gauge KENWOOD Bluetooth single DIN stereo POWERBASE component speakers/crossovers POWERBASE tweeters Wireless phone cradle/charger security: CLIFFORD concept 650 full system Dyno/power: September 2020 rolling road tuned: 1.3 bar (highest) setting - 650bhp Other settings - 500bhp and 450bhp Pops and bangs setting for giving oldies heart attacks too no sure on power level, gives flames. Also has low (95 octane) setting, all on switch in cabin. Body: Satin chrome wrap (Matt black with a hint of dark grey metallic in colour) Halo led rear light units Side skirt extensions WHIFBITZ front splitter with ears Carbon fibre cooling panel Carbon fibre viscous fan cover Tinted windows front and rear Underside: Everything removed including subframe, tank etc. Any surface rust removed, treated and chassis protection applied, followed by a full undercoat application. All backed up with pictures (lots) Bushes replaced with new genuine OEM. New OEM genuine full brake lines. Receipts for everything. Reason for sale: We’ve recently purchased a boat which was taking up any free time until just having received shit news about my mum having the big C and jumping strait into chemo. Therefore I’ve decided to sell the supra to fund a daily car upgrade and a nice holiday for mum whenever she’s able to have it. I will be taking fresh photos over the next few days and will upload in due course. Price: I’m looking for £37,500 If this ticks all your boxes, message me for a contact number. Negotiations possible. Thanks, Jay Edited June 29 by Crash Bandicoot (see edit history) 1 Link to comment Share on other sites More sharing options...
Peter P Posted June 27 Share Posted June 27 Best of luck with the sale Jay, sorry to hear about your Mum and hoping for the best with the chemotherapy. Looks like a lot of car for the money, hopefully it sells so you can get your upgrade on the daily and sort a nice holiday for your Mum mate. All the best, Pete Link to comment Share on other sites More sharing options...
Annabella Posted June 27 Share Posted June 27 As above, good luck with the sale, and even more good luck with your Mum. 1 Link to comment Share on other sites More sharing options...
MrGRT Posted June 27 Share Posted June 27 Adding to the comments. I don't know you but the big C is shit news, I hope you have a quick sale (sounds like a very good car for the money) and get an amazing holiday booked. Good luck Link to comment Share on other sites More sharing options...
Tyson Posted June 28 Share Posted June 28 On 6/27/2022 at 11:26 AM, Crash Bandicoot said: Uk spec with the usual Uk refinements: Bonnet scoop Engine EGR system Real leather front and rear seats Heated front seats Glass headlamps Etc. Matching engine/frame numbers Engine stripped and rebuilt/forged less than 5k miles ago. Runs like a dream. Originally auto, which has been replaced with a PMC kit mated with a BMW M3 6 speed gearbox. Been recently fully restored on the underside Was resprayed in original paint code prior to wrap. Wrap is matt black (slight metallic dark grey tint) wrap has been on a while now and is showing in areas. If I was keeping I’d have it rewrapped personally, I see it as a good protection for now, still presentable. Engine/exhaust: Block bored to 86.5mm, honed and decked Forged Manley pistons Full ACL bearings King thrust washers Head skimmed and pressure tested Valves reground New stem seals Following rebuild parts new oem: Full gasket set Water pump Oil pump Crank pulley Aux tensioner AEM 4” intake GREDDY intercooler kit BOOST LOGIC manifold ceramic coated T67 gen2 BB Precision turbo Heat blanket HKS bov HKS 50mm external waste gate Stainless downpipe and cat back Stainless cat back system Fuel/management: WALBRO 485 fuel pump AEROMOTIVE fuel pressure regulator DENSO 850cc injectors LINK G4 ecu with map selection switch BOOSTLOGIC traction/launch control Transmission: GETRAG 420g gearbox conversion Latest PMC adopt or plate and billet flywheel SPEC stage 3+ clutch kit Bailey one piece driveshaft Genuine clutch and brake pedals Genuine new gear surround TRD gear knob Uk spec big case LSD with cooler Cooling: Fluidine radiator Polished upper rad pipe and water neck Alloy expansion tank Suspension: TEIN Superstreet coilovers Front strut brace Brakes: KSPORT 8 pot front calipers KSPORT 360mm front bells/rotors Oem Uk spec rear calipers New OEM rear discs HEL braided brake lines all round Wheels/tyres: YOMOHAMA 18” Advan RS wheels Front 9j 245/40/18 pilot sports Rear 10j 295/35/18 pilot super sports Interior: MOMO Nero alcantara steering wheel TRD dash faces (not genuine) GREEDY boost gauge KENWOOD Bluetooth single DIN stereo POWERBASE component speakers/crossovers POWERBASE tweeters Wireless phone cradle/charger security: CLIFFORD concept 650 full system Dyno/power: September 2020 rolling road tuned: 1.3 bar (highest) setting - 650bhp Other settings - 500bhp and 450bhp Pops and bangs setting for giving oldies heart attacks too no sure on power level, gives flames. Also has low (95 octane) setting, all on switch in cabin. Body: Satin chrome wrap (Matt black with a hint of dark grey metallic in colour) Halo led rear light units Side skirt extensions WHIFBITZ front splitter with ears Carbon fibre cooling panel Carbon fibre viscous fan cover Tinted windows front and rear Underside: Everything removed including subframe, tank etc. Any surface rust removed, treated and chassis protection applied, followed by a full undercoat application. All backed up with pictures (lots) Bushes replaced with new genuine OEM. New OEM genuine full brake lines. Receipts for everything. Reason for sale: We’ve recently purchased a boat which was taking up any free time until just having received shit news about my mum having the big C and jumping strait into chemo. Therefore I’ve decided to sell the supra to fund a daily car upgrade and a nice holiday for mum whenever she’s able to have it. I will be taking fresh photos over the next few days and will upload in due course. Price: I’m looking for £39,995 If this ticks all your boxes, message me for a contact number. Negotiations possible. Thanks, Jay Sorry to hear that, you’ve not had it long either have you. Couple of months? I wish your mum all the best. Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted June 29 Author Share Posted June 29 On 6/27/2022 at 12:00 PM, Peter P said: Best of luck with the sale Jay, sorry to hear about your Mum and hoping for the best with the chemotherapy. Looks like a lot of car for the money, hopefully it sells so you can get your upgrade on the daily and sort a nice holiday for your Mum mate. All the best, Pete Cheers Pete, it’s going to be a tough few months, that’s for sure. appreciate the kind comments. Jay 1 Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted June 29 Author Share Posted June 29 On 6/27/2022 at 12:41 PM, Annabella said: As above, good luck with the sale, and even more good luck with your Mum. Thanks Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted June 29 Author Share Posted June 29 On 6/27/2022 at 8:50 PM, MrGRT said: Adding to the comments. I don't know you but the big C is shit news, I hope you have a quick sale (sounds like a very good car for the money) and get an amazing holiday booked. Good luck Thanks mate, hopefully she kicks the ass out of it! Jay 1 Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted June 29 Author Share Posted June 29 23 hours ago, Tyson said: Sorry to hear that, you’ve not had it long either have you. Couple of months? I wish your mum all the best. I’ve had it about 4 months mate, shame because it’s a really fun car and I had hoped to tinker and make it 100% like the last one I had. shame that we’ve been hit with this fork in the road. who knows, maybe sell the boat instead Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted June 29 Author Share Posted June 29 Price just dropped to entice some interest. Facebook post will be coming soon, good for interest, even better for time wasters… Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted June 29 Author Share Posted June 29 Photos added, please note there are some changes such as wheels etc, Will upload up to date ones when I move it out of the garage Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted June 29 Author Share Posted June 29 Under the wrap 2 Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted July 5 Author Share Posted July 5 I’m willing to drop to £35k for a quick sale… last chance idea before I get a loan to allow things to happen and put the supra under a cover in the garage for a while Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted July 15 Author Share Posted July 15 Bump. still here Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted July 21 Author Share Posted July 21 Bump, last drop £34k Link to comment Share on other sites More sharing options...
Peter P Posted July 22 Share Posted July 22 On 7/21/2022 at 11:48 AM, Crash Bandicoot said: Bump, last drop £34k Shocked this hasn’t gone, absolute bargain for someone with that spec. Shame I wasn’t just starting my search for another Supra or I would have snapped this up. Spent more on mine and still need to spend a load more on it. Best of luck mate, should surely find a buyer at that price. All the best, Pete 1 Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted July 23 Author Share Posted July 23 23 hours ago, Peter P said: Shocked this hasn’t gone, absolute bargain for someone with that spec. Shame I wasn’t just starting my search for another Supra or I would have snapped this up. Spent more on mine and still need to spend a load more on it. Best of luck mate, should surely find a buyer at that price. All the best, Pete Cheers Pete, I’m very surprised this hasn’t been snapped up, especially with the current price tag… a built engine manual (all be it a bmw conversion) that’s had full resto underneath with a relatively fresh paint job on top protected by a wrap is the perfect buy if I was looking (hence why I bought it!) I can’t drop any lower on the price so this is where it will stay until it sells now. flabbergasted it hasn’t gone yet, supra prices must be on a decline currently… 1 Link to comment Share on other sites More sharing options...
tayr Posted July 23 Share Posted July 23 I think having a wrap is working against you. People want to see what they’re buying imo 1 Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted July 26 Author Share Posted July 26 On 7/23/2022 at 3:28 PM, tayr said: I think having a wrap is working against you. People want to see what they’re buying imo I was thinking the same recently. when I find some time I’ll take the wrap off and add new images. See if that does the trick! 2 Link to comment Share on other sites More sharing options...
Tyson Posted July 26 Share Posted July 26 1 hour ago, Crash Bandicoot said: I was thinking the same recently. when I find some time I’ll take the wrap off and add new images. See if that does the trick! I think it will help, people always assume the worst and now parting with significant sums of cash for these cars, employ extra scrutiny. First thing that comes into my head if I was looking to buy a car that was wrapped is, it’s been used to cover scratches, damage or poor paintwork. It’s an unconscious thought that would stop me buying that car. Obviously this is just what goes on in my head and a general observation, nothing to do with you or this sale. Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted Wednesday at 08:07 PM Author Share Posted Wednesday at 08:07 PM Made a start today. paint underneath is very surprising… strangely a really nice colour actually! 2 Link to comment Share on other sites More sharing options...
mharvey Posted Wednesday at 08:58 PM Share Posted Wednesday at 08:58 PM 49 minutes ago, Crash Bandicoot said: Made a start today. paint underneath is very surprising… strangely a really nice colour actually! Definitely the right call. It does look an interesting colour. Good luck with the sale! Link to comment Share on other sites More sharing options...
Noz Posted Thursday at 10:11 AM Share Posted Thursday at 10:11 AM Pretty sure it's a Yaris stock colour. I really like it to be fair. Link to comment Share on other sites More sharing options...
raddys Posted Thursday at 01:14 PM Share Posted Thursday at 01:14 PM What's the original colour? Odd colour to spray a supra, never seen a baby blue one before Link to comment Share on other sites More sharing options...
evinX Posted Thursday at 09:00 PM Share Posted Thursday at 09:00 PM I remember this car from years ago. Had a life in Birmingham at some point. Wasnt that a skoda or fiat colour they used? Was hot in its day Link to comment Share on other sites More sharing options...
