3/4" Clutch master cylinder upgrade
Simo2007
 Share
Has anyone upgraded their clutch master cylinder to a 3/4" bore using the land cruiser clutch master cylinder?
The part number I have noted for the above is 31410-60372 (attached a pic below)
I have the slightest clutch drag so I'm not disengaging properly with a Spec 2+ clutch. When warm it gets quite difficult to engage reverse. No crunching at all just difficult to engage. I have replaced both the master and slave with brand new OEM with a braided line and bench bled etc. and I'm still having issues. I have also replaced gear selector bushes with solid bushings and transmission mount with OEM TRD.
Want to give this a try before going down the OS Giken twin plate clutch replacement route!
 Share
