Krimi's EU Spec VVTi Supra Single Turbo G35-1050 (The Journey, from Twins to Single)
Krimi
 Share
After 5 years since I sold my previous Supra, I came back to the Supra scene back in 16th of December.
94' EU Spec German Spec
120k in the odo and full stock!!
Compression test its awesome, overall status its 8/10, but not in love with the look, so in a near future I will receive a blast of parts to "Bring it back to its as new condition" and after that I will start with the project.
By now Im waiting to receive the car in 10 days because I live in Canary Islands and I purchased the car in Ibiza, so the car right now its shipped!
Here some pictures!
MOD LIST (8/12/2021) after 1 year of ownership:
ENGINE:
- Stock Shortblock
- Decarbonized
- New Toyota Oil Pump
- New Toyota Water pump
- New Toyota Timing Belt and hardware
- New Toyota V-belt and hardware
- New gasket and seal engine overhaul kit
- New PCV Valve
- New Toyota Engine wiring clips for the whole wiring
- NGK BKR7EIX
Turbocharger/Exhaust Components:
- Complete new CT12B hybrids machined OEM exhaust turbo housings
- TTC Mod
- New Toyota oil return hoses
- Whifbitz 3" Downpipe
- Whifbitz 3" Midpipe
- HKS Carbon Ti catback
Intake/Cooling:
- APR Cooling Plate
- Whifbitz 4" FMIC
- Whifbitz 3" FMIC pipes
- New Toyota Fan Clutch
- New Toyota Thermostat
- New Toyota Fan shroud
- Whifbitz Black Aluminium radiator
Fuel system:
- New Toyota Fuel Filter
- Tested and cleaned 550cc injectors
Engine Management/Electronics:
- Innovate lambda and boost controller
- Stock ECU (Link G4+ Extreme in the way)
- Innovate 5bar map sensor
- Full OEM Wiring check and restoration
Head:
- Decarbonized
- New Toyota Headgasket
- ARP headstuds
EGR full block off from the rear side of the head
- Brian Crower springs Ti tops
- Brian Crower billet valve locker
- Full head overhaul and measures by our machine shop
- New OEM Valve seals
- Stock EU/US camshafts
Drivetrain:
- GETRAG V160
- OEM driveshaft
- 220mm B03B diff LSD
- SuperPro Rear diff mounts
- RPS Carbon/Carbon clutch
- Braided clutch line
- OEM Toyota trans fluid
- ARP Flywheel bolts
- New Toyota clutch master cylinder
- New Toyota slave cylinder
Chassis/Handling/Brakes:
- KW Variant 3 Coilovers
- Hel Black Braided lines
- Motul Fluid
- Full Toyota calipers overhaul kit
- New Toyota brake pads
- EU Spec 4pot calipers
Interior:
- Recaro SR3 black retrimed seats
- OEM Black carpet
- OEM new door cards
- OEM new Speaker covers
- OEM Dash panels
- OEM Black leather back seats retrimed
- OEM Carbon 98' Steering wheel
- OEM New Floor mats
Exterior/Body:
- Full body and underside restoration and repaint in OEM 202 Black
- OEM S2 front wings
- Antenna delete
- Rear wiper delete
- Work Wheels Meister S1 3P 18x9,5 ET24 18x11 ET30 Michelin PS4 245/35/18 Front Michelin PS3 285/35/18 Rears
- RMM Front lip
- TwinZ Add on lips sideskirts
- ProSpec Imports Meisters center caps in billet
- OEM JDM bonnet (Optional: Seibon TS Carbon bonnet)
- Whifbitz Shine Style rear Carbon DIffuser
- Rear fenders rolled
- Front Fenders rolled
- 1998 OEM new Headlights
- 1998 OEM new Front indicators
- 1998 OEM new Rear tail lights
ACTUAL MOD LIST (02/10/2023) After nearly 3 years of ownership (637hp/808nm)
Engine:
- Brand new OEM Shortblock
- Radium press-in fittings for valve covers
- Nuke Performance Catch Can
- NGK BKR8EIX
- Fluidampr Crank Pulley
- PHR Black edition billet pulleys
- 36-2 Crank gear
- New Toyota Aristo Alternator
- VVTi Intake Manifold modified
Head:
- Brand new OEM VVTi head
- ARP headstuds
- Brian Crower STD Valves
- Kelford Stage 248/248 VVTi cams
- Garrett G35-1050 A/R 1.01
- CBS Racing Screamer pipe
- TurboSmart GenV ProGate 50mm
- K&N Long Air Filter
- Boost Pressure hardlines
- CBS Racing Exhaust Manifold and heat wrapped
- CBS Racing 3.5" Downpipe heatwrapped
- CBS Racing 3.5" Midpipe
- HKS Carbon Ti Cat-back
Electronics:
- MaxxEcu Pro
- CBS Racing Custom Wiring
- Audi R8 short-coilpacks
- Bosch Oil temp and pressure sensor
- Bosch Fuel temp and pressure sensor
- Individual EGT in the making
- Bosch Knock Sensors
- MAC 4-port Boost Solenoid Sensor
- CBS Racing Drive By Wire conversion Kit
- Bosch Throttle body 3”
Intake/Cooling:
- APR Cooling Plate
- Mishimoto S-Line Black Intercooler
- CBS Racing Custom 3" FMIC pipes
- Quick Release Security Clamps
- Whifbitz Carbon Fan shroud
- Koyorad Aluminium radiator
- Funk Motorsport Turbo Blanket
Fuel system:
- Deatschwerks 1200cc Injectors
- Radium Fuel Rail Top Feed
- Radium Fuel Filter and mount
- Radium Fuel Pulse Damper
- Radium Twin fuel pump hanger
- Radium Fittings and Fuel Lines
- AEM E85 Fuel Pumps x2
- CBS Racing Fuel Lines Holders
Drivetrain:
- GETRAG V160
- PHR 3.5” Driveshaft
- RPS Twin Carbon/Carbon clutch
- OEM clutch line
- RPS Flywheel bolts
- HEL Braided brake lines
- AP Racing DOT 5.1 Fluid
- TRD Strut Bar
Interior:
- OEM Black carpet
- OEM Dash panels
- JP Ledworks TRD LED Conversion
- JP Ledworks full LED HVAC conversion
- 2 DIN ATOTO Screen display to connect MDash to MaxxECU
Exterior/Body:
- Antenna delete
- Rear wiper delete
- RMM Front lip
- TwinZ Add on lips sideskirts carbon fibre
- OEM JDM bonnet
- Whifbitz Shine Auto rear Carbon DIffuser
Edited by Krimi (see edit history)
  • Like 2
  • 2 weeks later...
What a day!
Today I collect the car at the port, clean it, and take it for a drive, what a feeling haha, overall status its correct as I said, I have a bunch of OEM parts coming to do the "restoration" in some bits that I know that can be upgraded.
I will also do some paintwork in the rear arches, front wing, and bumpers because it has little dents all over this parts.
I will post a picture and list of everything when it arrives!
So happy with this new purchase, and looks stunning when its freshly washed.
  • 2 weeks later...
Hi guys, Im waiting for a lot of OEM parts like vaccum hoses, gasket kit, center console, etc...To bring back this old man to its bright life.
In Spain we have apart from Christmas, the 6th of January another "Gift" day hahaha, so my Girlfriend came up with this, but I will wait to install it till the Respray of the car.
  • Like 1
5 hours ago, mwilkinson said:
Great purchase, looks like it's in a nice condition.
Thanks god and the experience in the past, give me enough skills to detect the weak points of the Supras hahaha.
Lets see what happen when it goes single!
34 minutes ago, Spike3.0 said:
Looks great, bet it was amazing getting back in one after all those years away?
Hahaha, thanks, yes its amazing to have one of this cars again, and more knowing how the values are growing in LHD market and also in RHD’s.
  • Like 1
  • 2 weeks later...
Hi everyone!
Things start to arrive, Im expecting to receive  loads, and loads of parts in the next weeks, really excited!!
This time:
- KW V3
- Whifbitz 3row black radiator (This time I want an stealth look in the engine bay)
9 minutes ago, Peter P said:
Very nice! Hoping to get some new goodies for mine soon. Got to love a nice shiney part. Like the black radiator, should suit the stealth look nicely. 👍 :cool:
Extremely good looking, its just the polished one, painted by them with some “barbecue spray” lol, but really good finish
  • Like 1
  • Krimi changed the title to Krimi's EU Spec VVTi Supra Single Turbo G35-1050 (The Journey, from Twins to Single)
 Share
