T.T. Diff - Prop-Flange Info
T.T. Diff Prop-Flange
This is the most frustrating component to source for a Hybrid conversion and folks that break T.T. diffs :shrug: throw them away. :looney:
I have a Wanted Ad permanently running to try and unearth these Rocking-Horse droppings for Hybrid builds.
http://www.mkivsupra.net/vbb/group.php?discussionid=213&do=discuss
If you hear of a T.T. diff that's on it's way out, :amen: please save it's flange. :slap:
Recycle here
http://www.mkivsupra.net/vbb/group.php?discussionid=86&do=discuss
Thank you. :hi:
  • 1 month later...
  • 1 month later...
  • 2 years later...
With a small cold-chisel and hammer, carefully open the nut-lock as has been done here, take care not to split it
(Pic :hi: bluesonic94)
With the handbrake on, use a 35mm spanner and undo the nut.
Tip: A deep-socket and wrecking-bar or air-spanner is fine to undo it, however, a swan-neck ring-spanner will allow you to see the marks during reassembly.
Remove flange, fitting a new oil seal is good idea, fit alternative flange and steadily do the nut back up to EXACTLY where it was before.
Re-lock the nut.
  • 4 weeks later...
There are crush-washers beneath this assembly and it is ESSENTIAL these are not compressed any more.
Note: The nut may be tight to undo, don't let this mislead you to over-tighten during reassembly.
Get this simple little job wrong and you WILL kill the diff.
Tip: To prevent oil leaking past the splines, clean both male and female with brake cleaner and assemble with RTV on the female splines only.
T.T. diff prop-flange and Aristo transmission prop-flange are both size 'B' donut flanges.
These flanges have different part numbers, yet are suspiciously similar components? :think:
If you ever get the chance to remember to think to find out, please let us know?
T.T. diff flange: 41204 FLANGE SUB-ASSY, REAR DRIVE PINION COMPANION, REAR 41204-14010
Aristo transmission flange: 34780E YOKE ASSY, FLANGE 34780-30010
  • 3 years later...
 Share
