A/c Condensor and A/C pump..
jza800
 Share
Hi
Where is it possible to get new a/c compressor and a new a/c condensor???
Don't forget to throw in a new receiver drier as well. All Denso parts. You'll find all the parts here and can either buy here or shop around. You will always find a 5% discount code running for them somewhere online. Only downside is if the components originate from different locations as they don't consolidate orders, otherwise pretty good.
The most cost effective location for these parts will be sourced from the USA.
Ok how about where you connect the lines, do you take that from your old pump and move over to the new pump? as i can see that it is not the same??
All the Supra a/c parts are supplied by Denso, everything. So long as you have the correct Denso part number then you have the Supra part so everything will be the same. I wouldn't go by pictures as often sellers will just put a generic picture up. If the part number is correct then the part is correct. You'll just need to do some research into matching the Toyota part number to the Denso part number. It can be done, I know as I did it, I just don't have that cross reference info to hand to post up for you.
These are the part numbers for the 2JZ A/C parts.
The parts are scattered all over the place now, I checked Amayama.com and they only have the driers. I fitted an imported radiator from the US with the same description as below and it fitted as it should.
Rider had a thread going for complete AC kits some time ago, pressume they all gone though.
http://www.mkivsupra.net/vbb/showthread.php?341099-A-C-Condenser-kits-gauging-interest
88460-14310
CONDENSER ASSY, COOLER (the radiator)
https://www.ebay.co.uk/i/362463388685?ul_noapp=true
88471-34010
TANK, RECEIVER AIR CONDITIONER (the drier bottle)
https://www.ebay.co.uk/itm/Air-Con-Dryer-for-TOYOTA-SUPRA-A8-3-0-93-02-2JZ-GE-Petrol-Coupe-228-Behr/401678305681?fits=Model%3ASupra&hash=item5d85e48991:g:bQQAAOSwgnJcLPHx
88320-14600
COMPRESSOR ASSY, COOLER (the pump)
https://www.ebay.co.uk/itm/Toyota-Supra-Aristo-Lexus-GS300-IS300-2JZ-A-C-Aircon-compressor-Pump-447200-9813/113812304582?hash=item1a7fbdf2c6:g:Cu0AAOSwwAldJIqe
88460-14310
88471-34010
88320-14600
I have look on those parts, but the pump is not the same as the one i have on mine 2jzgte engine.. my Connections are next to each other. they are not that on the one on the add :(
Detailed earlier, its much cheaper to bring in from the USA and it takes about 4 days for in stock items to get to your door.
yes but cant find the one that fit my car, cant see the connections on them on their site.. mine is as i said my Connections are next to each other in a Straight line..
[ATTACH=CONFIG]232797[/ATTACH]This is my air con pump I think this is what you mean/want.
It was removed from my 2jz gte engine as the pulley is bent.[ATTACH=CONFIG]232795[/ATTACH][ATTACH=CONFIG]232796[/ATTACH]
Yes that is just like mine, i have sent you a pb..
  • 1 month later...
 Share
