Removing spoiler
Babe
How do I remove stock spoiler please? Needs to come off for respray but sprayer can't work it out.
Thanks:thanks:
Not being funny, but that's a bad sign to begin with.
There are two 10mm nuts, either side, accessed from within the bootlid panel.
There is a locator either side as well, but I don't think they are a clip of any sort.
The foam pad between the spoiler and the bootlid might put up a bit of a fight when separating the two.
I may be misleading you a bit on the foam.
There is a protector on each side, R/H: 76873-14061 & L/H: 76874-14061, but they're not sticky as such, they just bond with the panels and can tear.
I think mine had a few bits of adhesive padding added to the feet, by a previous owner, for whatever reason.
The two locators I mentioned (76879-14040) are listed as clips, so bear that in mind too when trying to free the spoiler.
As above two 10mm’s in each side under the plastic boot trim and 2 locating plastic clips on each side
Some people buy rubber adhesive sheet and cut out new gaskets themselves would imagine this is much cheaper than Toyota and maybe more convenient [emoji51]
