what would happen if
mark newman
 Share
From what I understand low impedence injectors run a lower resistance in ohm's compared to higher impedance injectors. If you run 12v through them with their lower resistance you create a higher current. This higher current can be high enough to burn up the ECU. The resistor pack just adds resistance to the injectors so less of a current is seen by the ECU and you won't be in risk of frying it.
but the car started
- - - Updated - - -
thanks for that
It just depends on what current the ECU's injector drivers are built to see.
Syvecs know what the ECU can safely run current wise, so it may have started, but it would be a risk not worth running for the sake of fitting a resistor box.
The higher currents could play around with the injector drivers on the ECU and just cause damage which isn't necessary.
 Share
