Mattsson mkiv RHD-LHD and NA-T Convension
mattsson
 Share
What hub dyno is that? Seems like very good load and long pull for 1000hp.
Your head has probably lifted. Also check if the ARP washers have sunken in the head and run the stock washer if your new ARP's still come with the narrow ones.
https://dl.dropboxusercontent.com/u/32139684/Musti/20140922_194003.jpg
  • Replies 136
  • 2 weeks later...
dyno is a land & sea eddy current hub dyno (telma broms) maximum hub hp is 1600 :)
im using ARP2000 bolts with arp washers this seaseon used for 4 seasons so now im changing to a ARP CA625 and Cometic HG
The D2 coils i got from MVP as always
And yes te car is for sale but i dont know what to do if i sell it.
  • 1 month later...
Update
I changed the HG and bolts the toyota oem tt gasket had leeakt between the layers.
And yes the arp washers that comes with the kits both 2000 and ca625 are smaler then the oem washers that i had been running so no problem ther
Hard to remember all but i think most of it is in the thred
Eagel Rods
Wiseco pistons
ACL berings
GSC Power Division Valve Spring Kit with titanium retainers
GSC Power Division S1 cams
New GTE oil pump for utelising the damper bracket and to move the trigger down so i can throw the dizzy as a trigger
Powerhouse Timing Belt Tensioner Bracket
Adjustable Camgears
ARP 2000 main rods Fw bolts
ARP CA6250 Head bolts
Cometic HG
Titan motorsport (ATI) Harmonic damper
Steel Flyweal
2400 Deka injectors running E85 and Flexfule sensor
AN8 fule line and OEM GE fulerail and regulator. rail is made to to fit 14mm injectors and feead is AN8
Twin Walbro GT450 fulepumps 2´nd pump activated ower 1.7bar boost aprox
China exhaust manifold used as a base 50mm wastegate
PTB 7675 billet turbo
6 individual EGT sensors for each cylinder and Maxxecu EMS
My own intake designe with 80mm tb redesigned with orings etc
Oilcooling with moded termostat sandwitch from vovlo B230FT
That is the base of the engine
Edited by mattsson (see edit history)
Eagel Rods
Wiseco pistons
ACL berings
Adjustable Camgears
Cometic HG
Steel Flyweal
Great, thanks for the list mate :)
Any ideas on what you want next if you sell her?
  • 6 months later...
 Share
