Pudsey Posted October 24, 2011 Share Posted October 24, 2011 Hi everyone, Brand new 'Power House Racing' engine breather system designed for big power Supras, but any Supra will benefit from additional engine breathing capacity. Please follow the link to Power House Racing's explaination of the system, which will detail everything you need to know. Link: - http://powerhouseracing.com/Templates/frmtemplateM7.asp?SubFolderID=11&SearchYN=N -------------------------------------------------------------------------------------------------------------------------------------- From Power House Racing's website: - Item PHR Race Engine Breather Kit for 1993-98 Supra Item # PHR 01011006-xx Anyone building a high horsepower/high boost 2JZGTE engine has to consider the effects of crankcase pressure at these levels. With the standard PCV valve (only 7mm) the engine simply is not able to remove pressure fast enough from the crankcase while under boost. The PHR Race Engine Breather Kit solves this problem, by increasing the venting area by over 200%. By removing crankcase pressure, you increase engine efficiency and therefore increase horsepower. This kit includes: •Hand-built aluminum vent tank with proprietary internal baffling •K&N 3'' Vent Filter(Not shown in picture, please Click here.) •Dual 12AN valve cover suction lines with nickel or Red & Blue plated fittings •12AN weld-on fittings for the valve covers Here are pictures below of it installed on "Supramn's" Motor: Breather Tank Kit Full View Installed Breather Tank Kit Close Up with "EXTRA LINE" added Breather Tank Kit Close Up connected to Modified Cam Cover Anyone who has ever put together 12AN lines and fittings can tell you how costly something like this is to put together. This is not merely an "oil catch can" but rather a complete engine breathing system for big boost/big HP engines. Stock or mildly modified engines can also benefit from this setup, but only slightly. You must remove the OEM charcoal canister in order to install the breather tank on the passenger side of the engine bay. Note: Please choose desired color fittings below. This kit includes: •Hand-built aluminum vent tank with proprietary internal baffling •K&N 3'' Vent Filter (Not shown in picture, please Click here.) •Dual 12AN valve cover suction lines with nickel or Red & Blue plated fittings •12AN weld-on fittings for the valve covers Anyone who has ever put together 12AN lines and fittings can tell you how costly something like this is to put together. This is not merely an "oil catch can" but rather a complete engine breathing system for big boost/big HP engines. Stock or mildly modified engines can also benefit from this setup, but only slightly. You must remove the OEM charcoal canister in order to install the breather tank on the passenger side of the engine bay. Power House Racing Website Pictures: - http://powerhouseracing.com/Merchant/images/Products/TT/Engperf/catchcan1.jpg http://powerhouseracing.com/Merchant/images/Products/TT/Engperf/catchcan3.jpg Note: Please choose desired color fittings below. MSRP $750.00 Your Price $699.00 -------------------------------------------------------------------------------------------------------------------------------------- For Sale: - Power House Racing Breather Kit with AN-12 Fittings. Condition: - Brand New and unused in the original packaging and box from the states. Picture Available: - Sale Price: - £380. No dibbs thank you, as I have tried this in the past and it doesn't work I am affriad. First to pay for the item will secure. If you choose to use Pay Pal you must cover the additional fees for using the service. Postage Arrangements: - Price Includes Postage in UK, overseas I will need to check. Availability Status: - Available. Other parts available in other sales adverts: - http://www.mkivsupra.net/vbb/showthread.php?244022-Chris-Wilson-VVT-i-1st-Decat-Pipe-Full-Stainless-Steel-with-1.0-bar-Restrictor-Ring.&highlight=Pudsey http://www.mkivsupra.net/vbb/showthread.php?244302-Brand-New-Setrab-Auto-Gearbox-Cooler-AN-Fittings-Braided-Lines.&highlight=Pudsey http://www.mkivsupra.net/vbb/showthread.php?244300-Brand-New-Setrab-19-Row-Oil-Cooler-AN-Fittings-Braided-Lines http://www.mkivsupra.net/vbb/showthread.php?243911-1-x-HKS-Pulley-Cam-Timing-Adustable-Tuning-Pully-Wheel.&highlight=Pudsey http://www.mkivsupra.net/vbb/showthread.php?243929-Brand-New-Power-Enterprise-800-cc-Fuel-Injectors-(Set-x-6). http://www.mkivsupra.net/vbb/showthread.php?257717-Polished-Alloy-Radiator-Expansion-Bottle. http://www.mkivsupra.net/vbb/showthread.php?257113-2-x-Sabelt-Race-Harnesses-4-Point-(4-inch)-(Black-amp-Yellow-in-colour). http://www.mkivsupra.net/vbb/showthread.php?257114-Brand-New-Power-House-Racing-Breather-Kit-with-AN-12-Fittings. Link to comment Share on other sites More sharing options...
