6 speed box. and front part of prop
dr_jekyll
hello. im looking for a getrag box and front prop only please
i have the following for my 5 to 6 speed swap.
2jzgte lighweight flywheel
stage 5 sprung clutch
so all i think ill need is the box and prop front .
or will i need a the slave cylinder also.?
thanks
craig the destroyer .
Craig, the stock Getrag expects a pull type clutch, have you not got a push type clutch? You could convert to concentric release with some machining work, or you may have to buy a pull type clutch if you want to use the stock Getrag release mechanism. Giken clutches can come with a movement reversal kit, but both clutch and kit are expensive.
  • 4 weeks later...
