Various Stainless Braided Hose Fittings + AN Adapters
Hoppy
AN12 straight fitting £5 (used)
2 x AN10 - 1/2" NPT (Male-Male) adapter £3 each (used)
2 x AN10 straight fitting £6 each (brand new)
AN10 bulkhead nut £2 (brand new)
AN10-AN10 (male-male) 90deg adapter £5 (brand new)
AN10 90deg push on fitting £7 (brand new)
AN6 female-female fitting £4 (brand new)
AN6 male T-piece £5 (brand new)
2 x AN6 blue hose finishers £2 each (used)
AN6 - AN4 (male-male) adapter £3 (brand new)
2 x AN6 45deg push on fittings (£5 new) / £3 used)
2 x AN6 90deg push on fittings £5 new / £3 Used)
AN6 alum weld on fitting £2 (brand new)
AN4 - AN4 fitting (male-male) £3 (brand new)
Large RED hose finisher (40mm max) £5 (brand new)
Or £50 delivered for the lot. Over £100 worth of good quality fittings here people
Cheers
Hi mate. I could possibly build you a AN10 oil return line, as i also have a length of unused AN10 braided hose here, if this would be big enough for you?. But you would need to source 2 AN10 adapters/flanges to bolt to your turbo + engine block.
Can't help you with with the oil feed line though sorry mate.I used a AN4 feed line with my T04Z, but i don't have these fittings or spare AN4 line.
ok how much for the an10 braided hose delivered?
