Crockett512 Posted March 19, 2010 Share Posted March 19, 2010 Evening all, I've just bought my supe from Dave_SZR, I've taken out the double din to fit my Alpine IDA-X001 from another car. He had literally only just fitted this, so it's pretty much as new! # Key Features # Double DIN Size Fixed Faceplate # 4 Line Mono Colour Full dot LCD Display # 50W x 4, 2 RCA Pre-outs # System Q-Ex, System E's+ # MP3/WMA/AAC-Decoder, 24-Bit Digital Audio Converter # Front AUX input with slide protection cover # Ready for Bluetooth Hands-Free Profile / Audio Profile # Blue Illumination + Emotional Illumination Effect # General Features # DIN Size 2 DIN # Faceplate Mechanism Non (Fixed) # Angle Adjustment No # Security Code Function # Key Illumination Selectable: blue, red or green # Rotary Encoder & Control Knob # Operation mode 4-Directions + Push + Rotary # Attenuator with Smooth Volume Return # Touch Sensor Tone # Digital Clock (24H) # All-off Select (20/40/60 minutes) # ISO connector # Display Features # Display Type LCD Display # Display Layout 4 line, Ful dot # Display Illumination BLUE # Spectrum Analyzer # Dimmer Control 2 steps - Automatic # Auto dimmer control function (on/off) # Positive/negative switchable # Display Off Mode # Demo Mode # Tuner Features # RDS (PI, PS, AF, TI, Clock) # Radio Text (RDS) # Radio Text Plus # Program Type Function (PTY) # Enhanced Other Networks Function (EON) # K3I - Clean Reception Tuner # FM Reception # AM (MW/LW) Reception # Presets 24 Presets (18FM / 3LW / 3MW) # Automatic Memory Entry (AME) # Up/Down Seek Tuning # Tuning mode (Auto1 / Auto2 / Manual) # FM Stereo / Mono Selector # CD Features # CD-R/RW Compatible # MP3 Playback with ID3 Tag Display # WMA (Windows Media Audio) Playback # AAC (Advanced Audio Coding) Playback # CD Text Support # Supreme # D.A.C. processing 24 bit (Burr Brown) # 0 bit Mute # Random Function (Track/Disc) # Repeat Function (Track/Disc) # Scan Function (Track/Disc) # External Media Control Features # Dual Changer Control (CH1, CH2 & AUX) # CD Text Ready with Compatible KENWOOD Units # Disc & Track Repeat # Disc & Track Scan # Disc & Track Random Play # Direct Access # Disc Name Preset Play (DNPS) # Bluetooth Handsfree with optional KCA-BT200 # Bluetooth Audio Streaming with optional KCA-BT200 # 2004 B.M.S. Amplifier Control # iPod Control with KCA-iP500 (optional) # Audio Features # Maximum Output Power 50W x 4 # MOSFET Power IC # Auxiliary input 1 RCA # Auxiliary input on Front # Auxiliary Type: Mini-jack # Pre-out: 2 RCA # Pre-out Output Level 2.5V # Preout Rear / Subwoofer Switchable # Subwoofer Reference Level Adj. # Built-In Amplifier Cut-Off # Dual-Zone Source & Volume Control # Dual-Zone (FRONT / REAR Switchable) # Source Tone Control & Memory Bass / Mid / Treble # Balance/Fader/Loudness Control # Att.(-20dB) with smooth Volume Return # System Q_EX (Preset & Manual Sound Control) # System E's+ (Built-in HPF & LPF) # Connectivity # External Media Control Bus (5L) # iPod I/F Control (5L-Bus) # Bluetooth Control (5L-Bus) # PS Amplifier Control System (5L-Bus) PS Amplifiers ('02 - '06) # iPod Digital Connection (1 Wire) # B.M.S.Control ('99-'03 Amps) # Advanced B.M.S. Control ('02 Amps) # OEM Wired Remote Control (optional adaptors required) # OEM Display Control (optional adaptors required) # Power Control (P.CON) wire # External Amplifier Controle Wire # 2-way (Tel/Navi) mute wire # Dimmer control wire # Cosmetics features # Front/edge: Black Injection # Dress plate: Metalic Black # Volume & operation knob or wheel: Chrome Plated # Preset key finish: Black Injection # Escution: Black Injection # Triangle Illumination: Red # Key illumination: Selectable: blue, red or green # Illumination Effect It only comes with the rear lead, but thats all you need for it to go straight in. It's a great unit, I'd have kept it if I didnt have the Alpine! £150 new, I'm after £100 inc P+P. Thanks! Matt Images aren't coming up, seperate link: Link http://picasaweb.google.com/MattCraneCustoms/ForSale#5450417273086330450 http://picasaweb.google.com/MattCraneCustoms/ForSale#5450417256378307490 Link to comment Share on other sites More sharing options...
